79 Corvette just died... Need help
Old 08-27-2011, 06:10 PM
Zapawaf
Zapawaf's Avatar
Default 79 Corvette just died... Need help
Hi,
I just recently (less then a week ago) bought a 79 Corvette off a relative and it died today less then 2 minutes from home.
It happened to fast to really say what happened, it just no longer went and became hard to stear off the road.
It was suggested to me that the alternator went (the GEN light did come on).
Called my local autozone and they happened to have one, just finished swapping it out, and it doesn't want to turn over, tho the radio and such work... If the alternator went shouldn't the battery be dead?
I just gave it an oil change (with new oil filter as well), this morning because it's new to me. I double checked all that, everything seems fine in that aspect. It ran for almost an hour before it decided to quit running.
Thoughts? Things I should check. It sucks having a new car that I've driven all of 3 hours in total, now sitting.
Old 08-27-2011, 06:18 PM
binster
Support Corvetteforum!
binster's Avatar
Run out of gas?
Old 08-27-2011, 06:19 PM
MelWff
MelWff's Avatar
Received 1,819 Likes on 1,608 Posts
It sounds like the battery is dead, try boosting it or if necessary replace it. The alternator light came on because the engine died. You should have had the autozone store check your old alternator before replacing it. It takes very little power to run a radio, a starter needs a lot more. Good luck.
Old 08-27-2011, 06:20 PM
Ganey
Ganey's Avatar
Engine suddenly turning off normally indicates the ignition module. It's good to carry a spare ignition module. So are you are charging the battery now?
Old 08-27-2011, 06:23 PM
onaqwst
onaqwst's Avatar
check your main ground wire FIRST.... actually just replace it and be done with it....
Old 08-27-2011, 06:27 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Does it click or make any noise when you try to start it?
A quick and easy check is to pull the headlamps on and have someone watch them, then try to start it.. if they go out it's a pretty good bet the battery is done. The battery may have enough to power the radio but not enough to start or crank over the car.
Post back with your findings.. if the battery is not bad then you'll need to check other things.
Old 08-27-2011, 06:29 PM
Tim H
Tim H's Avatar
Your going to have to have the alt checked then after thats figured out the battery is going to need charged.
After all that then you can check everything else like the module.
But do check for gas in the tank.
Old 08-27-2011, 07:35 PM
Zapawaf
Zapawaf's Avatar
It was recommended by a friend to try that and all it does it make this clunking sound but the lights practically cut out.
@Whoever mentioned going to autozone to test the alt'
Yea, I found this information out after I already made the swap.. The guy tested it and it ran but was very touchy, the feed to the battery if it moved would cut out so I don't mind the fact I replaced it. They're charging the battery right now ... fingers crossed. I'll let you know what happens from here. Thanks for the input thus far guys
Old 08-27-2011, 07:38 PM
Zapawaf
Zapawaf's Avatar
Hahaha there should be gas! I just put enough to bring it to 3/4 less then 20 minutes before!
Old 08-27-2011, 09:21 PM
Zapawaf
Zapawaf's Avatar
*****UPDATE*****
Well I have a new Alt and Battery and it still doesn't want to turn over.
It's thought that maybe it needs a new starter, and maybe it's dying out was something to do with the choke or carb? Thoughts?
Old 08-27-2011, 09:27 PM
'75
'75's Avatar
The next thing I would do is make sure the engine will turn by hand and is not siezed.
Old 08-27-2011, 09:47 PM
scottyp99
scottyp99's Avatar
Take the spark plugs out, so the engine won't make compression, and put a socket wrench on th bolt holding the pulley onto the crankshaft. Try to turn the engine clockwise, like you are trying to tighten the bolt. It should spin pretty easily.
Scott
Old 08-27-2011, 10:36 PM
7t9l82
7t9l82's Avatar
once again, check your battery to ground cable.
Old 08-27-2011, 10:52 PM
Zapawaf
Zapawaf's Avatar
If the battery wasn't properly grounded why would everything electrical (interior lights, headlights, dash and radio) all work?
Old 08-27-2011, 10:54 PM
7t9l82
7t9l82's Avatar
because of the load. the starter takes much more energy.
Old 08-27-2011, 11:26 PM
scottyp99
scottyp99's Avatar
7t9l82 is a pretty smart guy, you could do alot worse than to listen to what he has to say..........
Scott
Old 08-28-2011, 09:03 AM
binster
binster's Avatar
Originally Posted by Zapawaf
*****UPDATE*****
Just to confirm.. When you say "doesn't want to turn over" - is the engine cranking? or do you mean it won't start when cranking?
To 79 Corvette just died... Need help
Old 08-28-2011, 10:19 AM
Zapawaf
Zapawaf's Avatar
When I turn the key all I get is 1 clunk. It's not like it's even attempting to want to start.
Old 08-28-2011, 10:24 AM
beachcomber
beachcomber's Avatar
How many volts are you getting on the new battery?
Old 08-28-2011, 10:55 AM
binster
binster's Avatar
Manual tranny? May try pushing it and popping the clutch to see if you can start it? Sounds like ground problem as someone stated earlier if your battery is fully charged
Quick Reply: 79 Corvette just died... Need help
