82 fuel pump replacement
I need some advice on replacing a 82 fuel pump with a 85 pump. I removed the fuel door and rubber boot and notice that the sending unit is not even in the center of the fuel door opening . I plan to do the changeover with the tank attached. Do i need to loosen the straps to center up the tank with the fuel door opening for a easier removal? Thanks in advance
Lee
Lee
Lee
Lee
The sender will not come straight out....it takes a bit of a twisting motion.
Tap around the opening and a little more to prevent scratching the paint.
Maybe some one else will come along with an answer.
Jim
Drawmain, Can you send me a pm?
Just removed my pump, didn't loosen or drop tank. Just twist and move around, it will come out. use painters tape on car covered with duct tape to prevent scratching the area. Hope all goes well.
T
T
To make the extraction and reinstall easier, loosen the clamp on the R rear that holds the fuel and return lines, just take the bolt out, Then the fuel hoses will be easier to deal with.
After removing the mount bolts and disconnecting the electrical remove the R (Fuel) hoses first the move the assy to the R and remove the vent hose. A twist on the assy. to clear opening.
