L-88 hood clearance
L-88 hood clearance
Hi guys,
im planning my corvette project.
I have a 406 sbc ready to drop in a vette pretty soon. Car will be a 71 (still waiting on the confirmation of the purchase)
The 406 have dart pro1 head with a dart intake manifold, hvh 2 inch carb spacer and on top of it a Quick Fuel carb (4150).
Does someone know if i buy a L88 hood from ecklers im gonna have enough clearance and if i will be able to put an air filter.
Should i buy a long or standard hood? is their any other brand of "L88" hood that offer more clearance?
thanks!
thanks!
This is my 406,....not quite what you have, but the idea is similar. The RPM intake, Quick Fuel carb, and 4 inch KNN filter I have should be pretty close in height to what you are planning. I ran the same setup under my stock 80 hood but with a two inch filter element for years.
Vanacor is the only vender I have found that makes an L88 high rise hood, that should fit this,...and that is the one I plan to use. It's supposedly two inches taller than most other aftermarket L88 hoods.
I still have a few odds and ends to finish up before I get to ordering my hood,..but as it stands that is the hood I plan on using.
I was just checking mine out tonight I have a dart intake 4150 no spacer on the long l88 ecklers hood and have about an inch from the vent tubes with the hood closed. Those dart intakes are tall and I wish I had the vanacor hood. My car is a 71, bbc though, it would be worth the wait if there is one for the taller hood cause I would imagine I'll loose a little running a 2" filter. I'm going to order a k&n with the filter top the PO removed the duct work in the hood.
