completely screwed up, and now i need a bit of help
well, i absolutely ****ed up this evening. i was putting the last few little pieces on the motor, and my wrench slipped, the oil pressure plug popped off, flew behind the paper towel and tinfoil i had laying in the lifter valley, and made its way somewhere between the cam and the crank.
i pulled the oil pan off and i still cant find the damned little thing.
if it makes any difference, it went down the drivers side very rear hole. (pretty sure at least, that thing went flying) ive stuck my fingers down there, looked all over with a light, and even flipped the motor over and pulled the oil pan off. i cant see it, at all.
so now what? can i gently turn the motor over by hand and hope it shows up or falls out?
The only thing that I can think of that I would worry about here, is scratching a cam lobe. I would think that if you moved the crank gently, you probably won't do any harm.
Scott
Scott
I would also look around on the floor as I have dropped many things and watched them fall and think I know exactly where it was but always found it somewhere else.
One thing may help for the next time is an extendable retrieval magnet. I checked the one I have, and it's made by a company called Carica. Dont know what kind of magnets in it, but this thing picks up a 2 foot pipe wrench. Also has a retractible magnet sleeve, so it wont stick to the sides of things. Checked around, and found Betty Mills Co. She has a large assortment of this brand, including a flexible one.
Location: Las Vegas - Just stop perpetuating myths please.
Dude the suspence is killing me!
Hope your story has a happy ending for us and please post your results,
cardo0
I think u have enough posts now to write a book on changing heads. Well at least u ask for help before u get into trouble. I have seen a timing belt change (non-corvette) turn into a complete overhaul before.
cardo0
cardo0
cardo0
cardo0
