Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2011, 06:05 PM   #1
beernut
Junior Member
beernut's Avatar
Default Coolant leak, new thermostat house gasket
Alrighty folks, another noob question for the masses
My 81 at some point had a bad leak from the thermostat housing and it was corroded pretty bad. I took the thermostat house off, cleaned it off real good and painted it with a cast iron refurbishing paint. Checked the house and all looked good afterwards.
Anyways, I installed the thermostat house with a new gasket this evening and tightened the bolts "a fair bit"(no torque wrench used.) Everything looked fine until the car heated up and I noticed a tiny bit of coolant coming out between the gasket and house.
What's really strange though is that I saw coolant beaded up on the house itself...note that this was after a short drive so it might have gotten there because of vibration - I would find if very strange if it bled through the house itself.
So, to the question - is there any danger involved in further tightening the bolts (how much load should I put on them?) Also, do you guys recommend using a sealant in addition to the gasket?
tl;dr: Small leak from newly installed thermostat house. How much torque should be applied to bolts? Should sealant be used?
Picture of the leak here (caked coolant is from old leak, still not cleaned up properly): Click the image to open in full size.
Cheers and thanks!
beernut is offline   Reply With Quote
Old 08-02-2011, 10:48 PM   #2
petes74ttop
CF Senior Member
petes74ttop's Avatar
Default Cheers to you to!
Yes you need sealant on both sides of the new gasket.
A "Fair bit" of tightening should be good, correct torque for those bolts is 22 -32 Ft-lbs (30-44 Nm).
petes74ttop is offline   Reply With Quote
Old 08-03-2011, 03:36 AM   #3
beernut
Junior Member
beernut's Avatar
Great, thanks for the info
Old 08-03-2011, 08:02 AM   #4
Sigforty
CF Senior Member
Cruise-In IX Veteran
Sigforty's Avatar
Send a message via AIM to Sigforty Send a message via MSN to Sigforty Send a message via Yahoo to Sigforty
What gasket did you use? I suggest going with one of the Fel-pro gaskets with the build in silicon ring. I think they are under the Printoseal line.
Sigforty is offline   Reply With Quote
Old 08-03-2011, 08:20 AM   #5
beernut
Junior Member
beernut's Avatar
Quote:
Unfortunately the supply here in town is very limited so I had to go for a stock replacement gasket...not sure what material it was made from but felt sort of like paper. Definitely no silicone ring in it.
Either way, I'll get some sealant today and see if that'll take care of it - thanks for the tip though, I'm sure it won't be the last gasket I replace
Old 08-03-2011, 11:31 AM   #6
Sigforty
CF Senior Member
Sigforty's Avatar
Here is the FEL-PRO Part # 35562T, for what I use.
Old 08-04-2011, 04:05 AM   #7
beernut
Junior Member
beernut's Avatar
Great, thanks!
Old 08-04-2011, 05:40 AM   #8
gingerbreadman1977
CF Senior Member
gingerbreadman1977's Avatar
Send a message via MSN to gingerbreadman1977
use this stuff called permatex under the housing on both sides of your gasket and ill bet you never have a leak again . Doesnt hurt to paste some on your threads either when you screw your bolts in either. Its what i use on water pump bolts on the threads that go right through to the water jacket.
gingerbreadman1977 is offline   Reply With Quote
Old 08-04-2011, 08:46 AM   #9
LancePearson
CF Senior Member
Support Corvetteforum!
LancePearson's Avatar
I'm trying to remember what I did wrong one of the times I put a different temp thermo and gasket. had to put tstat in first into recessed spot for tstat, seat it, then put gasket on.
no sealant..works great. must put tstat in first!
LancePearson is offline   Reply With Quote
Old 08-04-2011, 02:34 PM   #10
beernut
Junior Member
beernut's Avatar
Thats actually what I did, but I probably didn't tighten the bolts enough...going to work on it tonight tho so I'll let you know
Reload this Page Coolant leak, new thermostat house gasket
Tags
bit, c3, c4, c6, coolant, corvette, felpro, gasket, jacket, leak, leaked, normal, silicone, thermostat, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
