How do I remove locking lug nut?
Old 07-30-2011, 07:25 PM
GRIZ73
GRIZ73's Avatar
Default How do I remove locking lug nut?
I am changing tires and wheels on a 73 convertible I have recently acquired. I did not receive the locking lug key. How do I remove the locking lug? Any help will be greatly appreciated. Thanks!
Old 07-30-2011, 07:27 PM
Clubby99
Clubby99's Avatar
Take it to a tire install store. They have tools for that. Costs like $20. Better than you messing with it.
Old 07-30-2011, 07:38 PM
scottyp99
scottyp99's Avatar
I'd take it to a place that installs tires, they will probably have a tool that does it.
There is a tool that is for removing bolts and screws with stripped heads, get your hands on one of those and it should work. Harbor Freight, maybe?
Scott
Old 07-30-2011, 08:15 PM
qwank
qwank's Avatar
Find a 12 point socket thats just smaller then the locking lug, and hammer it on. you should be able to get it off.
Old 07-30-2011, 08:20 PM
7t5
7t5's Avatar
St. Jude Donor '14
Old 07-30-2011, 09:38 PM
Tim H
Tim H's Avatar
If its only 1 the tighten the other 4 real tight then grab the locking one with vice grips and turn it off.
Old 07-30-2011, 09:42 PM
BPHORSEGUY
BPHORSEGUY's Avatar
Location: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Old 07-30-2011, 10:49 PM
blckslvr79
blckslvr79's Avatar
I've done this before.
Old 07-31-2011, 03:53 AM
6t9427
6t9427's Avatar
If you have a welder, weld an old lugnut to the locking lugnuts.
Old 07-31-2011, 06:32 AM
dgood
dgood's Avatar
Had the same problem with my car a few years back. Took it to the tire store (lees Tires)here in va beach and they did not have a lock that fit it. Used a socket and pounded it over the lug nut and it came right off. It took two sockets because the first one split down the side. 10 minutes per tire. cost 60 bucks. I guess I could have done it at home if I would have thought of it.
Old 07-31-2011, 07:05 AM
Vette5.5
Vette5.5's Avatar
There's actually special gripper sockets with sharp edges to bite in some shops have. Combine this with their air impact wrenches, and pretty difficult to replicate for most home users. Some locks, like McGard are hardened, and hard to grip into. For fun try drilling a hole in one. A little torch heat usually solves the problem, but at the risk of damaging the wheel.
Old 07-31-2011, 07:39 AM
johnmb
johnmb's Avatar
It was for just such applications that Harbor Freight was hatched.
Old 07-31-2011, 12:08 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
DO NOT do this. It's bad juju for the wheel hubs. You wouldn't torque a single lug to spec at full capacity before doing any of the others, right? Would you be willing to put a 200+ lb impact load on a single stud?
Old 07-31-2011, 01:07 PM
7t9l82
7t9l82's Avatar
get an impact socket and drive it on with a hammer. impact sockets are much stronger.
Old 07-31-2011, 11:05 PM
GRIZ73
GRIZ73's Avatar
Default locking lug nut removal
Thanks all. I used 12 point socket worked fine. Thanks again!
Old 08-01-2011, 12:23 AM
ylose
ylose's Avatar
Yep, buy 4 of them. Had to do that to the wife's car when the damn service tech lost the key years ago.
Old 08-01-2011, 12:51 AM
blckslvr79
blckslvr79's Avatar
What in the hell are you talking about???? We're talking about removing the lock nut, not installing one. No one is torqing down 200+ lbs???
To How do I remove locking lug nut?
Old 08-01-2011, 12:53 AM
blckslvr79
blckslvr79's Avatar
Glad it worked for you.
Any damage to the hub???
Old 08-01-2011, 01:58 AM
Shark Racer
How much force do you think you're applying to the hub when you hammer the socket on?
Where do you think the force is being applied?
Do you check the rotor surface before and after with a dial indicator?
Anything I can say to respond to this would be a violation of the forum rules.
Did you even read my post? Do you know the difference between "impact load" and torque?
Old 08-01-2011, 03:51 AM
Vette5.5
Vette5.5's Avatar
While getting a bit off topic, kinda freaky thing happened. Been using a set of McGards for years transfered to 3 seperate cars. Bought another new set for a different car. I'll be damned, if it wasn't the exact same pattern, using the same lug key. I always buy an extra key, and hang it with a copy of the number card on the basement wall.
Quick Reply: How do I remove locking lug nut?
