1982 Corvette crossfire flooding.
Remove the white connector on the ECM and clean it. Thats the one for the engine light. Clean both connectors while you are at it.
Pin 20 on the white connector is the light. Should go on with a test light put to it. If not everything suggests bad connections, bad ground or bad ECM.
