Quadrajet off idle bog cure
Old 04-29-2002, 12:34 AM
American Boy
American Boy's Avatar
Default Quadrajet off idle bog cure
I was having a hard time in finding the cause of it. After checking with the document by Lars, I did adjust the secondary opening rate by turning the spring 3/4 of a turn and it improved a lot. From a dead stop, almost no bug but when cruising at 30 mph and nailing it, flat on it's nose and then boom :seeya.
After more search, I found that my choke pull-off diaphragm was torn. This thing have another fonction that is to control the secondary opening with vacuum load.
Now, no more bug anywhere. My L48 with 3.07 even spin the tire when a nail it from a stop. Well not a burnout but a little spin.
Now it's time to take the top of that carb to adjust the internal.
I tought I'd share my finds.
P.S. thanks Lars for giving me the courage to tune the Quadrajet Beast. :D
Old 04-29-2002, 09:28 AM
xfactor974
xfactor974's Avatar
Default Re: Quadrajet off idle bog cure (American Boy)
Try pump cam yet? That's helps in Holley's and Demons.
Old 04-29-2002, 10:07 AM
Captain Morgan
Captain Morgan's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Congratulations.
Now, I have an off topic question for you, only because of where you are from. A friend was telling me the pronunciation is Kay-beck, but I've always heard it pronounced Qwa-beck. Which is correct?
P.S. Beautiful vette. What wheels are on it?
Thanks,
[Modified by sharklover, 8:08 AM 4/29/2002]
Old 04-29-2002, 01:27 PM
Frank75
Frank75's Avatar
Default Re: Quadrajet off idle bog cure (sharklover)
Anglophones typically pronounce "Qua-bec", mais en francais, on dit "Kay-bec". There is an accent on the "e" which makes it sound like a hard-A.
I hope you don't mind my answering this one American Boy, but I lived in Quebec a long time and am still fluent.
Old 04-29-2002, 02:10 PM
American Boy
Default Re: Quadrajet off idle bog cure (Frank75)
Your absolutely right about Québec. The wheels are TTII 17" X 8.
Stephan
To Quadrajet off idle bog cure
Quick Reply: Quadrajet off idle bog cure
