potential water leak
Old 07-04-2011, 10:01 PM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
Default potential water leak
how can i reseal this without pulling off the fender? Photo taken from cowl drain screen pointing back towards rear (unless i got the pic upside down)
https://www.facebook.com/photo.php?p...6&id=515538771
Old 07-05-2011, 11:11 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
I'm assuming everyone can see that link
Old 07-05-2011, 11:17 AM
jcloving
jcloving's Avatar
For those of us at work, corporate IT won't let us see anything on facebook. Please use photobucket.
Old 07-05-2011, 11:25 AM
BTGRN75
BTGRN75's Avatar
St. Jude Donor '11
Maybe shoot a little weather seal foam on it ??? The one for window sealing that has the small tube extension and doesn't expand much. Just a thought.
Old 07-05-2011, 11:27 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Old 07-05-2011, 11:35 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
What is that grey stuff and can it be replaced or just leave it and reseal?
Old 07-05-2011, 12:01 PM
BTGRN75
BTGRN75's Avatar
St. Jude Donor '11
I think the grey stuff is the seam sealer that was used back then. I'm sure you can't get it now nor would you want to. I'm summarizing that you can't get to it easily -why I recommended the spray. Otherwise you could smear it with a better matching caulk.
Old 07-05-2011, 12:45 PM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
...What is that grey stuff...
Looks like factory bonding compound to me.
Can you reach the spot with 3M automotive undercoating?
FWIW: I don't see any evidence of a water trail/leak in your pic. Everything looks clean and dry.
Old 07-05-2011, 03:39 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
I'm using a snake cam to get in there to take the picture.
Maybe I can take a better quality pic.
when I put a garden hose to my windshield, I get water streaming into the car.
Old 07-05-2011, 10:34 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
found my leak.
i removed the leaf catcher and the rubber seal that goes at the corner of each window.
the two brackets that attach to the fender aren't sealed.
Are they supposed to be or is the rubber that is above supposed to make them water tight?
To potential water leak
Quick Reply: potential water leak
