Short vs Long Water Pump
Old 06-17-2011, 04:52 PM
BOSTONCAMARO
BOSTONCAMARO's Avatar
Default Short vs Long Water Pump
hi
I have a nice small block, complete with accessories, pulleys etc.
Can I swap this into a 69 Corvette with a long water pump, will I have clearance issues with using a long water pump and its accessories?
www.sfaboston.net
Old 06-17-2011, 05:20 PM
Scott Marzahl
Scott Marzahl's Avatar
Nope, short water pump only for a Corvette or you hit the frame crossover.
Old 06-18-2011, 06:08 AM
corvettedave383
corvettedave383's Avatar
Iam not sure if the frame is different on a 69, compared to my 78 vette frame, but ive got a long water pump on, without any clearance issues
dave
Old 06-18-2011, 12:59 PM
Dustup7T2
Terrorizing Orange Cones
Support Corvetteforum!
Dustup7T2's Avatar
dave
Hi Dave,
I understand that the frames are almost identical from 1963 to 1982. Can you post a photo of yours?
That may help explain which pulleys are driving any accessories too.
Old 06-18-2011, 05:58 PM
corvettedave383
pic of pulley at crossmember
pic of water pump pulley and alt
there seems to be plenty of room between the crank pulley and crossmember
cheers
dave
Old 06-18-2011, 06:45 PM
Dantana
Dantana's Avatar
i think the big thing you have to watch is that if you try to take the accessory brackets from your corvette and put them on the new engine with the long pump they won't line up. You need to take the whole assembly (alternator bracket, P/S brackets, etc) and keep them consistent with the long pump.
Old 06-19-2011, 03:20 AM
corvettedave383
the power steering bracket lined up fine, needed new pulleys for the water pump and a new bracket for the alt, also the crank pulley is new to suit a long pump setup
dave
Old 06-21-2011, 10:13 AM
BOSTONCAMARO
I have a complete long water pump set up now on the engine, so maybe I will swap it in and see what I have for clearance issues if any. Anyone have a long water pump set up in a 68 or 69? thanks, Tim
Old 06-21-2011, 02:11 PM
Condo_454C3
Condo_454C3's Avatar
I was under the impression that long water pumps were fine for small block cars. I could be wrong so take that advice with a little caution.
Old 06-21-2011, 02:31 PM
Mike Ward
Mike Ward's Avatar
Nope, the matching crank pulley will hit the crossmember.
Old 06-22-2011, 08:06 PM
BOSTONCAMARO
ok, so I will need a short water pump set up, what should I use for a 69? is that the ultra short one? it appears two different variations were made?
To Short vs Long Water Pump
Quick Reply: Short vs Long Water Pump
