Manual transmission fluid??
Old 06-02-2011, 12:03 AM
vettegirl25
2nd Gear
vettegirl25's Avatar
Default Manual transmission fluid??
Hi, I just bought a 1981 vette and we are in the process of changing all the fluids because it had been sitting for awhile. What kind of fluid do I use for a 4 speed manual transmission? What we drained what red and thin. Any help would be great.
Old 06-02-2011, 12:23 AM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
Gm atf
Old 06-02-2011, 05:05 PM
FKING1
FKING1's Avatar
Penzoil Syncromesh.
Recommended by Keisler for my TK600 5 spd.
Old 06-02-2011, 05:28 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
qkull:
Why GM atf in a manual transmission?
Old 06-02-2011, 06:12 PM
Schaggy
Schaggy's Avatar
Dunno... I never heard of using ATF in a manual. I've always used straight 90 weight gear oil or the newer 80-90. I'm currently running the 80-90 in my '72 M20 4-speed.
Old 06-02-2011, 08:10 PM
enroberts
enroberts's Avatar
Originally Posted by gkull
Gm atf
I've always used ATF even in manual transmissions. Chances are the previous owner of the OP's car did also according to their description of the drained fluid...
Old 06-02-2011, 08:33 PM
udornf4
udornf4's Avatar
I've been around car restorations for 45 years. Never heard of ATF in a manual transmission.
ATF = automatic transmission fluid
The proper fluid is 85W-90 weight (or the like)...
My .02
Old 06-02-2011, 08:52 PM
Faster Rat
Faster Rat's Avatar
Never heard of ATF in a manual transmission either.
Look, my local vette/muscle/collector car expert puts this stuff in all the high dollar vehicles that he works on. It is made by Lubrication Engineers, called Duolec 1604. It is 90W, red and quite pricey...if I remember correctly. After my M-21 was rebuilt, he sold me however many quarts required (2.5-3.0?) out of his bulk drum. The gears are quiet and smooth as silk.
http://www.le-inc.com/products.jsp?productID=307
I'll probably never add or change it again, so who cares what it costs. I paid around $750 to have my tranny rebuilt and re-sealed. Ouch.
Old 06-02-2011, 09:08 PM
68sbcoupe
68sbcoupe's Avatar
Default ATF in a manual trans
Using ATF in a manual trans is not uncommon. Honda, Toyota, and BMW do. I used ATF in the manual trans in my race cars for years. 40 years of racing, and never a transmission failure. Not one.
jb78L-82
jb78L-82's Avatar
I changed my 4 speed fluid in the early 90's and used Amsoil gear oil. Recently changed it again with Mobil 1 75W-90 full synthetic as well-it is perfect-quiet, and the shift handle never gets hot as it used to with the OEM GM gear oil. I would not use automatic transmission fluid in a 4 speed manual!
Old 06-02-2011, 10:18 PM
63split63
63split63's Avatar
I use Mobil 1 10 w 40 in my muncie tranny,s . Never had any problems.
Bill
Old 06-02-2011, 10:48 PM
alswagg
alswagg's Avatar
Borg Warner manual transmissions require ATF Note, base stock oil in ATF if 10wt oil. Many transfercases also use ATF. Muncie transmissions require gear oil of 85/90 wt. The main diffeance are the bearing cleances. Al
Old 06-02-2011, 11:19 PM
scottyp99
scottyp99's Avatar
My brother's '97 'vette uses atf in the manual transmission, had a couple dealerships tell us the same thing, we scratched our heads over it for awhile, couldn't figure out why.
Scott
Old 06-03-2011, 12:09 AM
72LS1Vette
72LS1Vette's Avatar
Scott
The T56 transmissions specify ATF. It's on a sticker affixed to the trans IIRC. I know the 2001 Camaro trans that I have clearly stated that ATF should be used.
Rick B.
Old 06-03-2011, 08:59 AM
udornf4
udornf4's Avatar
Rick B.
Well, I be hand-dipped in horse do do. Learn something everyday!
Old 06-03-2011, 09:06 AM
jb78L-82
jb78L-82's Avatar
I was aware that some newer manual transmissions used automatic fluid like the 4+3 in the C4's as well as my 1988 Mustang 5.0 manual but have never seen it specified for older 4 speeds like the M22/M21/Borg Warner Super T-10's or in any C3. So are you saying that there are C3 manual transmission cars that had automatic fluid filled from the Factory?
Old 06-03-2011, 09:48 AM
MelWff
MelWff's Avatar
I would love to see what it says in the back of an 81 owners manual concerning fluids, anybody have one?
To Manual transmission fluid??
Old 06-03-2011, 11:54 AM
rj8806
rj8806's Avatar
On newer manual transmissions, i.e. T5, TKO, T56's, you MUST use either ATF Dexron III or Pennzoil Syncromesh (GM Syncromesh is actually called out in the literature but the Pennzoil stuff is cheaper and readily available). Gear oil is way too thick to use in these gearboxes.
Like the Muncie's, the newer 5 and 6-speeds do not work as well with a full synthetic as it is too "slippery" and does not provide enough "bite" for the syncro's and blocker rings.
Everything I know about manuals, says 75/90 is the preferred fluid for the older 4-speeds.
Richard
Technical Sales Support
American Powertrain
Old 06-03-2011, 01:36 PM
Mike Ward
Mike Ward's Avatar
I could have sworn the OP said that she has an '81 w/4speed. No mention of any modifications.
Who gives a sh*t what other makes/years of cars with other transmissions use?
The following 2 users liked this post by Mike Ward:
Cmurray79 (03-06-2020), patg84 (08-06-2019)
Old 06-03-2011, 02:30 PM
gkull
gkull's Avatar
I went with what the poster originally said. That and the fact that my 1991 Ford 4X4 has used ATF from day one. I worked on a 80's Camero and it had ATF in it's 5 speed. So it has probably been at least 30 years ago that major manual tranny manufacturers started using ATF. I'll research it, but ZF transaxles like in GT-40's and Panteras might have been using ATF in the late 60's
If you know anything about manual trannys how could you not hear of them using ATF?
http://www.amsoil.com/products/trans...fluid_rec.aspx
Quick Reply: Manual transmission fluid??
