Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-15-2011, 02:52 PM   #1
drwet
CF Senior Member
drwet's Avatar
Default 16 or 17 inch wheels
I'm due for new rubber. Not worn out. Just old. I have 255/60-15 BFG's on it now. I like the size, but there's not much available in 15" anymore. Anyone have 16 or 17" wheels and tires that work out to about the same size. Any pics?
drwet is offline   Reply With Quote
Old 05-15-2011, 03:29 PM   #2
MrForce
CF Senior Member
St. Jude Donor '11, '14
MrForce's Avatar
Send a message via AIM to MrForce
16" tires are on the way out as well, selection wise. Look at 17" or 18" or depending on how you roll (pun intended) 17's and 18's.
Rob
MrForce is offline   Reply With Quote
Old 05-15-2011, 03:50 PM   #3
fugawi
CF Senior Member
fugawi's Avatar
18's are yor best bet. boss 338 18x8 all around with 245/45 front, 255/50 rear.
Click the image to open in full size.
fugawi is offline   Reply With Quote
Old 05-15-2011, 03:53 PM   #4
Ben Lurkin
CF Senior Member
St. Jude Donor '09
Ben Lurkin's Avatar
I like 17's. 18's give you too much of that "donk" look on the older vettes.
Ben Lurkin is offline   Reply With Quote
Old 05-15-2011, 03:56 PM   #5
AGVI
CF Senior Member
Canadian Events Coordinator
AGVI's Avatar
Go for the classic 'Torque Thrust II' by American Racing.
Product Number: 5057861
Product Description:
17X8 TORQ-THRUST II 5X4.75
Fully polished
Backside Spacing (in/mm):4/102
Offset: -11.43 mm
Les
AGVI is offline   Reply With Quote
Old 05-15-2011, 04:18 PM   #6
Gordonm
CF Senior Member
Gordonm's Avatar
17 or 18 the selection of sizes and rubber are way better. I have 17 front and 18 rear.
Gordonm is offline   Reply With Quote
Old 05-15-2011, 08:23 PM   #7
3JsVette
CF Senior Member
3JsVette's Avatar
Don't even consider the 16s. If you are looking to upgrade 17s or 18s are the way to go. There are plenty of options with tire size to stay near the stock 27" overall tire diameter.
3JsVette is offline   Reply With Quote
Old 05-15-2011, 08:53 PM   #8
LT1driver
CF Senior Member
LT1driver's Avatar
18 doesn't look right on older cars, you want those sell and move up to c4-c6 car.
LT1driver is offline   Reply With Quote
Old 05-15-2011, 09:13 PM   #9
binster
CF Senior Member
Support Corvetteforum!
binster's Avatar
18 inch rear and 17 inch front
275-40-18 rear and 245-45-17 front
binster is online now   Reply With Quote
Old 05-15-2011, 11:41 PM   #10
carbster09
CF Senior Member
carbster09's Avatar
Default 16s ... :(
I ran 255/60/15s and upgraded to 16" rims .. I liked the way they look however the rubber selection is limited and hard to get a hold of. I ended up with Dunlops D8000's I think ... on the rear. The look is good but I am going to upgrade again to 17s. I wish I would have gone that route the first time!!
carbster09
carbster09 is offline   Reply With Quote
Old 05-16-2011, 06:57 AM   #11
CFD E59
CF Senior Member
CFD E59's Avatar
I have to say those Torque Thrust look sick... I have gone both ways for shows I put the stock wheels on with BFG, and have 17's for fun.
CFD E59 is offline   Reply With Quote
Old 05-16-2011, 07:02 AM   #12
73jst4fun
CF Senior Member
73jst4fun's Avatar
Quote:
Rob
I've had 16" before and there's not much to choose from...17" and 18" are your best choice and have a good size selection and they will look close to the stock size...jmo
__________________
1973 #'s match red convertible: 350 sbc, forged rotating assembly, AFR 195 heads, Comp Cams solid roller cam: 230/236@ .50, 552/564 lift 110 LSA, 10.70 comp/530hp, Mighty Demon carb, MSD ign, Spal fans, Hooker comp headers Jet Hot coated, Vette Brakes suspension front and rear, Steeroids, Sharkbar, Tremec TKO 500, Fidanza flywheel, CF dual friction clutch, 3.55 gears, 17",18" TT II wheels, Kumho MX 255/45VR17's, 275/40VR18's.
73jst4fun is offline   Reply With Quote
Old 05-16-2011, 08:24 AM   #13
jb78L-82
CF Senior Member
jb78L-82's Avatar
Forget 16's. I run 17's on SLP rims which fit perfectly with zero modifications or spacers. 255/45/17 ZR's in front and 255/50/17 ZR's in back. Don' buy junk tires with S/T speed ratings if you want maximum performance!
[IMG]Click the image to open in full size.[/IMG]
jb78L-82 is offline   Reply With Quote
Old 05-16-2011, 08:30 AM   #14
Buddy1980
CF Senior Member
Default Aftermarket wheel sizes for C-3
I have a 1980 C-3 that I am currently restoring. It had the original 15"x8" wheels with 255-60-17 tires. I had to go with larger wheels to clear some new larger C-6 Z06 brakes front and rear. I had access to a set of 17" wheels and also a set of 18" wheels. These wheels had tires mounted so I had a few car guy friends come over and we looked at the 17" and 18" wheels on the car, switching them back and forth a few times so we could get a good look. We all agreed that although the 18" wheel would work, the 17" wheel seemed to fit the car a little better as far as not making the wheel look to large for the car. I then ordered some 17"by9" wheels from Year One, they call them snowflake wheels, they are a remake of the 70's Trans Am wheel. They kind of look like the old BBS wheels that you see on some older cars, I've seen the BBs on a lot of older BMW etc. Anyway, the wheels fit perfect and the 1980 Corvette centercaps snap on these wheels. Hope this helps. Thanks
Buddy1980 is offline   Reply With Quote
Old 05-16-2011, 02:38 PM   #15
MIKE80
CF Senior Member
MIKE80's Avatar
Here's a couple pictures of my 1980 with 17x9.5" Z06 wheels, 2.5" wheel adapters, and Nitto NT555 Extreme tires 275/40 ZR17 front and rear. Plus, I can rotate the tires.
MIKE80 is offline   Reply With Quote
Old 05-16-2011, 03:01 PM   #16
aaroncorvette
CF Senior Member
17 or 18" Vintage Wheel Works V40's
http://www.vintagewheelworks.com/products/wheels/v40
aaroncorvette is offline   Reply With Quote
Old 05-16-2011, 03:14 PM   #17
glackore
CF Senior Member
glackore's Avatar
Dude, 17's and 18's are the way to go! Find the style you like and do your homework on the back spacing and tire width/height. There is a lot of excellent advice on the forum.
glackore is offline   Reply With Quote
Old 05-16-2011, 10:27 PM   #18
eagle275
CF Senior Member
eagle275's Avatar
anybody have the website for Paul's Wheels? CA or FL, can't remember which. Also has a cool photo gallery. Thanks!
Update: found it - Pete Paulson Wheels ( was close on the name - it's been a couple of yrs since I saw that on here ) Has 14"-17" steel rallys, and 16.5"-20" billet aluminum.
http://www.petepaulsen.com/home.htm
http://www.petepaulsen.com/Catalogof...y%20Wheels.htm
http://www.petepaulsen.com/Catalogof...t%20Rallye.htm
eagle275 is offline   Reply With Quote
Old 05-18-2011, 04:06 PM   #19
TopHat
Junior Member
TopHat's Avatar
Tophat0220
I just bought some Boss 338's, 18x8 front and 18x9.5 rear. They fit perfect.
TopHat is offline   Reply With Quote
Old 06-14-2011, 03:59 PM   #20
tonyponykay
CF Senior Member
tonyponykay's Avatar
Default how does rim size affect clearance
I'm also considering new rims for my 80... i am wondering how does rim size and tire size affect my exhaust clearance?
if i go 17 inch rims and the required tires, will my clearance go up? I want it to go up about half inch if possible or a little bit more maybe...
with a full tank of gas my heavy 240 lbs body in there, sometimes my new exhaust rubs on high bumps in the road...well it did once... but i would like it to have a little better clearance..
any knowledgeable person's advice will be greatly appreciated..
thanks
tony
tonyponykay is offline   Reply With Quote
Reload this Page 16 or 17 inch wheels
Tags
16, 17, 17x95, 1980, 76, c3, c6, corvette, inch, performance, rim, size, tire, wheels, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
