Second Opinion on a 383 Engine Build Sheet??
Old 06-16-2011, 01:55 AM
Bud2
Bud2
Support Corvetteforum!
Bud2's Avatar
Default Second Opinion on a 383 Engine Build Sheet??
G'day, Thinking of putting together a 383 for my '64. Could use a second opinion if I'm on the right track. Below is the background and parts list.
The Car and UsageThe car is a ’64 Corvette coupe, 4 speed wide ratio transmission. 3125 curb weight. Professionally built differential, using a 373 gear ratio. Long Tube Headers – 1.5 inch Diam. 2.5 inch flow through exhaust (no cats, no crossover - yet). 26 inch tall tires.
It’s used on weekends of which 40% of that time is on the drag strip (usually bracket racing on an eighth mile). Not a daily driver. But still needs to be streetable.
Goals:
383ci, 500hp at the crank, shift point @ 6000rpm, limited @ 6500rpm, pump gas (petrol available is 92, 95, or 98 Octane, E10 is 94.). Not a budget build but neither is it an all out heart-stopper.
I think I want to have:(DCR 8-8.5 This may mean 10.5 CR for Alum heads)
350 Chev Small Block. Seasoned 4-bolt block, two piece rear seal. Machined and prepared for 383 rebuild. 30 thousand over. Decked to 9 inches
Scat Crank - 9000 series cast steel, #9-350-3750-6000 (935056), Stroke 3.75”, 6”, Rod Pin – 2.1.
Scat Premium 7/16 bolts, connecting rods 6inches long (383 ready) #2-350-600-2100-DLS (6600021QLS), 6”, Crank pin – 2.1, Wrist Pin - .927, BE Width - .940, Grams – 569.
Kit number 1-90460BI-X $1280.00 (The X is for the 7/16 rods). Comes with the following piston package.
SRP forged pistons
Total Seal Classic Race file-fit rings
Lunati Cam #DV294-06HRH. Hydraulic Roller. Duration 294/243. Lobe lift 0.373. Lift –0.615”. Recommended Springs 73100 $337.16 (out of David Vizards’ book)
Hydraulic Roller Lifters (Spring Loaded) Lun-72400LUN. Roller Lifters (Spring Loaded) Lun-72400LUN. $319.95
Push Rods. Length???
Roller Rockers – 1.65 ratio Lunati #72430LUN
AFR Heads. 195 Eliminators . #1094, Angled plugs, 75cc Combustion chamber. #1095, Angled plugs, 65cc Combustion chamber. Under cut valves, 8mm stems, 3 x angle ground, Exhaust valve is radiused. Priced at $2080 from AFR. (Need #8019 Springs) (Ask for 7/16 rocker studs) THIS IS NOT THE FULL RACE HEADS.
Weiland Action Plus intake #8004 two plane. Idle through 5,500rpm. (I already have) (I’ll pick up an air-gap single plane later)
Carburettor - Proform 750 vacuum secondaries. One inch open spacer. (I already have)
Holley fuel pump (110GPH) (Summit HLY-12-327-11) $81.95
Damper - POWERFORCE+PLUS SFI SERIES 9000 #90000 (6.75”)
Cloyes Timing Chain. Clo-9-3100A. $129.95
Mister Gasket Timing Cover Kit. MRG-1099. $55.95
Gaskets……………FelPro 1010 head gasket for alum. Heads. FelPro Engine set.
MSD Ignition. Corvette V8 Tach DriveDistributor w/Vacuum Advance Part No. 8572. 6AL Trigger Box (2 x rev limiter)
MSD Super Conductor Wires 8.5mm. Red. $51.95
Mini High-Torque Starter (I already have)
Summit Pro Pack: Oil Pan and Pump Kits. (Blueprint pump) $285.70
Summit Fabricated Valve Covers. $189.95
Summit Engine Bolt Kits. Stainless Steel – Allen Head. SUM-56490HS – 36.95
ARP Harmonic Damper Bolt ARP-134-2501 $21.61
ARP Pressure Plate Bolts. ARP-130-2201 $11.64
ARP Head Bolt Kits. ARP-134-3601. $73.48
ARP Main Bolt Kits – 4 Bolt Mains. ARP-134-5202. $39.29
ARP Chemicals - Assembly Lube. ARP- 100-9909. $6.68
ARP Chemicals – Thread Sealer. ARP- 100-9904. $8.75
Thermostat Housing – OEM and paint, OEM Thermostat
Block Protector Plate – eBay
Speed Pro Scatter Shield (I already have)
McCleods Billet Flywheel and twin disc clutch (I already have)
What have I missed?
Bud.
Old 06-16-2011, 09:23 AM
jackson
jackson's Avatar
500fwhp goal
Unless your machinework is free-of-charge or you already have a prepped block ...
Perhaps you'd be ahead in both money and power if you began with a DART SHP 400 ShortBlock (new block, crank, rods, pistons & bearings).
CF member Jim "427Hotrod" used one last year & penned article about it.
http://www.dartheads.com/products/sh...k-builder.html
Old 06-16-2011, 09:27 AM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
TQ is what can drop your time a couple of 10ths. When I was doing the 11.70's in my Vette similar build with 3.875 strokers for 396 ci we doing 11.40 - 50's at the all corvette drags.
I have never built another 383. They are nothing. Everybody has them.
The cam. the rule is. when you have big flowing heads you need less cam. http://www.lunatipower.com/Product.aspx?id=1990&gid=289 is out of bounds for a little 383 with 195 E heads
with your choices of fuel. 64 or so cc with flat tops. your headers are to small for the heads. look at the head port size.
Old 06-16-2011, 11:38 AM
larrywalk
larrywalk's Avatar
With that combination and your goals, I'd use a larger intake manifold such as the Edelbrock Performer RPM Intake Manifold. Also, I'd swap the carb for a 800 mechanical secondary carb, which has the same primary size (same driving characteristics, but less restriction at WOT).
For pushrods, you'll need to measure after the long block is assembled - too many variables otherwise.
Old 06-16-2011, 07:52 PM
Bud2
Bud2
Bud2's Avatar
Default Thanks for the imput....
I looked at the new after-market blocks but for a couple reasons I'll stay with the older version at this time. I'm not real comfortable selecting the cam. I contacted Lunati about that cam. They said it would work fine. Could you give me a part number of another one that I could investigate????
Cheers.
Bud.
Old 06-16-2011, 08:49 PM
Indiancreek
Indiancreek's Avatar
Bud, is that pic of the red one the 64 you are building the engine for? Man, that car is nice. I'd hate to see it get all torqued up over time as good as it looks.
I'll send you a c3 and an engine or two and trade you for it. Ok, I'll throw in my dog and a couple cool guns ( oh, can you have them?)
Julian
Old 06-16-2011, 09:18 PM
Bud2
Bud2
Bud2's Avatar
Default G'day Julian
Yup, the 383 is going into the '64. As with a lot of cars, pictures don't show the true story. It's a nice car but it's far from a NCRS Top Flight candidate. I don't want to see it buggered up either and I'll try not to but the funny thing is my life-style leads me this way. I work 7 nights a week (wifes' restaurant) and in my own shop 5.5 days a week (jeweller). Wife gets motion sickness real bad so no tours or even short trips. I enjoy the mechanics of the corvette hobby. So if I didn't have the goal of racing on the strip, the car simply wouldn't get out of the garage! I love this car but I gotta have some fun too.
Thanks for the offer tho, but no guns allowed here. We can't even carry sharps (knives) without due cause - as in work related not protection. You could call our state a 'Nanny State' and not many people would disagree.
Now get off the computer and get back working on my block!
Bud.
Old 06-16-2011, 10:16 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Need 1.75" primaries 3" collector if poss.
Old 06-16-2011, 11:11 PM
eagle275
eagle275's Avatar
Old 06-16-2011, 11:51 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
You will be over 500 HP & 6500 RPM racing. Look at a quality forged bottom end.
Here is a great 396 kit. Add internally balanced. With the 75cc AFR 195 eliminators your at about 10.5 to 1.
http://www.cnc-motorsports.com/produ...68&CtgID=28766
I agree cam is too big. This one with your 1.65 rockers and efficient exhaust will work well and be right under 8.5 DCR.
http://www.summitracing.com/parts/CCA-12-450-8/
Old 06-17-2011, 02:55 AM
Bud2
Bud2
Bud2's Avatar
Default Decisions, Decisions
Seems I'm on the border of everything. Most of the gear is set up for 6000rpm and 500hp. So I'm either overdoing it on some things and in danger of breaking others. The bottom end is supposedly rated at 500. With my 1.5 inch exhaust and dual plane intake I'm expecting to maybe make 500. This isn't an all out build, that's one of the reasons I'm staying with the seasoned block. I'm just trying to get the most out of the tires and diff I've got on.
I'll look into that other cam. Thanks for the lead.
Time to shift over to the restaurant job - I can hear the wife calling!
Bud.
To Second Opinion on a 383 Engine Build Sheet??
Quick Reply: Second Opinion on a 383 Engine Build Sheet??
