Power brake vacuum hose
Old 02-03-2013, 01:16 PM
Iron_dog
Iron_dog's Avatar
Default Power brake vacuum hose
Hi , does anybody knows the difference between GM 342411 and GM 354698?
Old 02-03-2013, 11:35 PM
BHRIG
BHRIG's Avatar
The 342411 and 354698 are both 11/32 pipes with a fitting on one end used from carb to power brake booster
Hope this helps.......
Old 02-04-2013, 01:18 PM
Iron_dog
Iron_dog's Avatar
Hi thanks yes I know, but is the same item?
Old 02-04-2013, 01:44 PM
BHRIG
BHRIG's Avatar
GM lists both as being same...............possibly different manufactuers
Old 02-04-2013, 01:57 PM
restoman1
restoman1's Avatar
Looks like the only real difference is the mounting bracket configuration. And even that's not a lot.
1974 only 342411
1975-1976 354698
Ed
Old 02-04-2013, 06:07 PM
my 76 ray
my 76 ray's Avatar
1974 only 342411
1975-1976 354698
Ed
The fitting that screws into the carb is much longer on one.
Old 02-05-2013, 11:00 AM
Iron_dog
Iron_dog's Avatar
Yes thanks everybody! I confirm the mounting bracket of the 74 is about 3/8 in longer, this is the only differrence between the two tubes!
To Power brake vacuum hose
Quick Reply: Power brake vacuum hose
