350 zz4- fuel pump push rod- whats the trick?
Old 05-09-2011, 09:17 PM
mikejpss
mikejpss's Avatar
Location: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default 350 zz4- fuel pump push rod- whats the trick?
There MUST be a double top secret way to hold the fuel pump push rod in the "UP" position while you fumble around installing the fuel pump.
And don't go tellin me:
a.theres a bolt on the block front face to remove and install a longer bolt that will hold the rod in the up position....
or.......
b. a blob of axle grease on the rod will hold it up..
There is such close clearance around the fuel pumpthat it took me an hour to install.....that push rod MUST have a way to be held up....Anybody wanna share their procedure?
Old 05-09-2011, 09:32 PM
tonyv123
tonyv123's Avatar
I always use a long thin screwdriver, push the pushrod up as far as it will go, hold it with the shaft of the screwdriver, and slip the pump arm in. Kinda tricky, but it'll go. Once the arm is in, keep the pump aligned as much as possible. Usually takes me two or three tries.
Old 05-09-2011, 09:47 PM
DRIVESHAFT
DRIVESHAFT's Avatar
I use a hack saw blade in place of the screwdriver, but same concept.
Old 05-09-2011, 09:58 PM
rugerm44
rugerm44's Avatar
Or you can just remove the bolt going thru the front of the block that lines up with the pushrod.replace it with a longer one.snug it with rod in the block but don't crank down on it.it will hold long enough to install the pump.just don't forget to remove it and install the shorter one before you crank it.it gets noisy.right out of the chilton manual.
Old 05-09-2011, 10:03 PM
mvette76
mvette76's Avatar
wheel bearing grease!!!!
Old 05-09-2011, 10:15 PM
mikejpss
mikejpss's Avatar
There IS NO SUCH port on the block front of a ZZ4 small block . Actually, ther eis a port, but it has a bottom, it does NOT go thru the block into the pushrod cavity.
Old 05-09-2011, 10:16 PM
mikejpss
mikejpss's Avatar
Did NOT work for me. Even made sure the pushrod was bone dry,free of engine oil.
Old 05-09-2011, 10:29 PM
alswagg
alswagg's Avatar
I install ZZ4 rotating assy several times a year on Marine applications. Basically the same type of fuel pump and push rod. I do grease the push rod with synthetic grease, but to hold it up. I use a 8" long feeler gauge .030. Another item which can be used is a patch knife.
Al
Old 05-10-2011, 01:33 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Did you 'bump' the engine over until the camshaft lobe for the fuel pump was "off" the rod? If not, you'll never get it together. Once you have the pressure off the rod, grease will keep the rod in the 'up' position until you get the fuel pump seated.
Old 05-10-2011, 01:38 AM
Ralphbf
Ralphbf's Avatar
What he said.
Old 05-10-2011, 01:40 AM
AZDoug
AZDoug's Avatar
Received 1,477 Likes on 904 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
TDC on #1 is where you want to be.
That puts the pump cam at lowest lift.
Doug
BTW, I should have specified firing position, #1 TDC. The other TDC will put the pushrod cam exactly where you don't want it.
Doug
Old 05-10-2011, 08:28 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
I just made sure the cam was set to leave the rod high up in the block and held it in with my finger as I put the pump and arm up in there. when I pulled my finger out the rod dropped on the pump arm and I just started the bolts from there.
Old 05-10-2011, 09:14 AM
mikejpss
mikejpss's Avatar
This is what I did Sig, but with the close quarters it took a few tries. Like an hours worth!. The pushrod was able to move up so there was no need to "bump" the motor, cam lobe was in the up position already.
Thanks for all the ideas. I was in hopes there was a radical, new, double-top secret procedure that I didnt know about.
Old 05-10-2011, 12:08 PM
c3corvette77
c3corvette77's Avatar
First you have to turn the car on it's roof, just kidding. I've always used wheel bearing grease to hold it up, use a pretty good wad too. Make sure the cam is off the lobe and it should work.
Old 05-10-2011, 12:15 PM
DO2G
DO2G's Avatar
more grease...
Old 05-10-2011, 01:00 PM
chevygod
chevygod's Avatar
Hack saw blade, long screwdriver, needle-nose pliers, push-it-up-and-move-really-fast, lotsa bad words, and beer in an autoparts parking lot that my friend brought by one time. These have all worked for me.
The bad words and beer worked best...
Old 05-10-2011, 03:55 PM
mikejpss
mikejpss's Avatar
Could I get the lady in your avatar to help ?
To 350 zz4- fuel pump push rod- whats the trick?
Quick Reply: 350 zz4- fuel pump push rod- whats the trick?
