Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-07-2011, 10:06 AM   #1
BillyTz06
CF Senior Member
BillyTz06's Avatar
Default Help, Oil Filter blew out at start up
I started my new 350 engine build last night and within a minute of running, the oil filter gasket blew out and the oil filter balooned out like it was ready to bust at the seams. I lost all of the oil before I noticed the oil pressure had dropped to zero as I was watching the tach trying to maintain 2000 to 2500 rpm and keep the engine running. Of course I shut it down as soon as I noticed the oil pressure drop and then we saw all of the oil on the floor. Has any one heard of this happening before and what would be the cause?
BillyTz06 is offline   Reply With Quote
Old 05-07-2011, 10:29 AM   #2
birdsmith
CF Senior Member
birdsmith's Avatar
Was it a stock pump? There may be an obstruction somewhere in the oiling system downstream of the filter...how much pressure is the gauge reading? If you're getting a normal or somewhat low pressure reading at the gauge (Which is tapped from the last possible spot in the oil circuit) it would indicate a restriction in the system somewhere between the filter and the gauge tap...
birdsmith is offline   Reply With Quote
Old 05-07-2011, 10:36 AM   #3
BillyTz06
CF Senior Member
BillyTz06's Avatar
Hi voluum, oil pump,,fram filter,when priming the pump it was 60 psi start up was about 80 psi
Old 05-07-2011, 10:49 AM   #4
dar322
CF Senior Member
St. Jude Donor '12-'13
dar322's Avatar
wrong oil filter?
dar322 is offline   Reply With Quote
Old 05-07-2011, 10:55 AM   #5
BillyTz06
CF Senior Member
BillyTz06's Avatar
Yeah,I just found out. Probably the worst filter I could have used.
Old 05-07-2011, 11:05 AM   #6
dar322
CF Senior Member
dar322's Avatar
what Fram model? was it the wrong one or a mfg issue?
Old 05-07-2011, 11:06 AM   #7
BONESTK87
CF Member
BONESTK87's Avatar
Yep Fram filters suck!! Put a AC Delco on it.
BONESTK87 is offline   Reply With Quote
Old 05-07-2011, 11:44 AM   #8
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
This is very strange. Fram has been criticized for filtering efficiencies but I don't recall anecdotes about such an out-and-out failure. A great deal of (seemingly excess) pressure was being generated for some reason; something you will have to track down.
paul 74 is offline   Reply With Quote
Old 05-07-2011, 11:49 AM   #9
7t9l82
CF Senior Member
7t9l82's Avatar
i used to run Hastings filters for that reason the case was thicker than anyone else's plus the densite material filtered really well. but i haven't seen them around in years. filters are critical. its a shame about fram they were a good brand once upon a time
7t9l82 is online now   Reply With Quote
Old 05-07-2011, 01:08 PM   #10
Manuel Azevedo
CF Senior Member
Manuel Azevedo's Avatar
Quote:
There is suppose to be a oil filter by pass on your oil filter adapter. When the flow is more than the filter can flow it opens and by passes the filter. Either yours is not present or someone blocked it off trying to get full oil flow. Wrong thing to do. Check it out.
Manuel Azevedo is offline   Reply With Quote
Old 05-07-2011, 01:52 PM   #11
Indiancreek
CF Senior Member
Manuel is correct, the bypass should have opened to off pressure. Some guys block the bypass to force all the oil through the filter, and still don't blow up the filter.
I'm wondering about the bearing install someplace blocking an oil passage?
I don't think under normal situations most any filter will do that.
Indiancreek is offline   Reply With Quote
Old 05-07-2011, 02:20 PM   #12
C5SCCA
CF Senior Member
C5SCCA's Avatar
Can you post a picture of the oil filter? I have never seen a filter "balloon."
C5SCCA is offline   Reply With Quote
Old 05-07-2011, 02:49 PM   #13
Jeff_Keryk
CF Senior Member
Jeff_Keryk's Avatar
I'm guessing there was some obstruction of the crank, cam or rods resulting in a sudden higher than normal pressure.
Jeff_Keryk is offline   Reply With Quote
Old 05-07-2011, 02:58 PM   #14
Ben Lurkin
CF Senior Member
St. Jude Donor '09
Ben Lurkin's Avatar
Sounds like the pressure relief plunger in your oil PUMP is stuck. That's what regulates pressure, not the filter bypass.
Ben Lurkin is offline   Reply With Quote
Old 05-07-2011, 03:17 PM   #15
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Yup not the filter at fault here, track down the problem before you do some real damage
MotorHead is offline   Reply With Quote
Old 05-07-2011, 03:42 PM   #16
BillyTz06
CF Senior Member
BillyTz06's Avatar
The by pass works fine, oil pump fine, correct fram filter. All of the racing gurus around here say the fram filter will not hold up under a hi volume oil pump. The fram walls are paper thin and the gasket is not well positioned for performance applications. I now have a K&N filter installed. The difference in filters is astounding. We'll see how this one holds up. Try googleing oil filters and see the rating for yourself.
Old 05-07-2011, 03:59 PM   #17
babbah
CF Senior Member
babbah's Avatar
I have always run a K&N filter in my BB with Melling HV oil pump. Not cheap - but no problems!!
babbah is online now   Reply With Quote
Old 05-07-2011, 05:36 PM   #18
Manuel Azevedo
CF Senior Member
Quote:
The filter bypass redirects the oil flow when pressure is higher on the pressure side than the side to the engine regardless of oil pressure. (restricted filters regardless if new or just dirty.) So if an oil filter can not flow what the pump puts out it is bypassed, if not you get a ballooned filter or worse. It is differential pressure that makes it open nothing to do with pump pressure. Oh well each to their own opinions right or wrong!
Old 05-07-2011, 05:55 PM   #19
Corey_68
CF Senior Member
Corey_68's Avatar
THAT's your problem... Fram filter's are prone to failure and can/have destroyed engines. Neighbor had a new I-6 installed in his Cherokee and the filter came apart internally, clogged the pump and destroyed the engine.
Fram not only paid 100% for a new engine, but 100% of the removal and 100% of install without batting an eye.
Do a search om Fram filters.
Go with a WIX or Napa Gold.
Corey_68 is offline   Reply With Quote
Old 05-07-2011, 06:10 PM   #20
volition
CF Senior Member
I had the same thing happen and had to experement with a few filters.
On my application, the bypass I installed would cause certain filters to bottom out and not fully seat. This caused the seal on the filters to blow out.
Finally settled on a Fram PH30 that fit right. Will be changing that to K&N once my break in is complete, though.
volition is offline   Reply With Quote
Reload this Page Help, Oil Filter blew out at start up
Tags
350, blew, blow, blowing, chevy, engines, filter, filters, fit, fram, gasket, high, motors, oil, ph30, pressure
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
