pinion seal change diff out.
Old 05-11-2011, 01:37 PM
rugerm44
rugerm44's Avatar
Default pinion seal change diff out.
What's the best way to keep things from turning while loosen and retighten the yoke nut.I did a search but all I can find is replacement in the car.all pointers are welcome.Im also changing the side yokes and seals.the diff cover is still on the car.so that's no help as far as holding it.
Quick Reply: pinion seal change diff out.
