Spark plug question Iridium? Platinum?
I am looking for advice on new spark plugs.
I currently run Bosh 4008 Double Platinum plugs and fire them through a DUI (Davis unified ignition) distributor in my slightly modified 1976 L48 (heads, intake, cam, carb) with original 35 year old short block.
Its time for new plugs, I have been happy with the double platinums but over time they do have some build up.
I am looking for advise about Iridium plugs.
Good? Bad? Better? what brands are best?
or should I stick to Platinums?
Thanks John
Thanks John
I find the stock ACDelco plugs work the best in GM cars, and that goes for all year makes and models
The biggest advantage to those pricey plugs is their longevity.
Major BS on some new engines just to change the plugs.
Your current plugs are fine, if you're happy with them.
Location: San Diego - Deep Within The State of CONFUSION!
If you're driving a modern fuel injected vehicle that is designed to go many tens of thousands of miles between services, then these types of plugs make sense. Our c3 engines certainly do not fall into this category
One of the benefits of owning the car that you do is that there is no disadvantage whatsoever in running an inexpensive spark plug. I concur with the AC Delco or Autolite selections.
I have seen direct side-to-side dyno comparisons from an engine builder that I know (as opposed to a magazine article where the plug manufacturer had purchased advertising) proving that there is virtually no measurable difference between cheapo run-of-the-mill AC or Autolite plugs and the super hi-dooda-dooda plugs used by NASA on the Space Shuttle. Of course these comparisons were done on low-tech pushrod carbureted engines, but honestly the best thing you can do for an old, low-tech carbureted car's ignition system is install an MSD box, add a good set of wires, and then index the cheapo plugs. Spending all that $$$ for superheterodyne unobtanium filament plugs is just a waste unless you're the guy at the parts counter selling them. If you don't want to contaminate your Vette's original underhood look, install a Pertronix. The AC plugs in my Pertronix-equipped C3 currently have 30,000 miles on them and the car's perfectly happy.
My heads use the flat gasket 14mm .750 deep reach plugs. Summit Racing did not have the autolite Iridium plugs in stock at the counter so I bought the double plantinum 3924
My ignition would eat common plugs for lunch. I pulled my common plugs once to look at the jetting and the center electrode was rounded and erroded away to where the gap was near .080. It still seemed to run fine.
I'd like to find a multi tipped or side ways jumping spark plugs
My heads use the flat gasket 14mm .750 deep reach plugs. Summit Racing did not have the autolite Iridium plugs in stock at the counter so I bought the double plantinum 9324
The fancy metals just wear less, and wear leads to misfire, whether detected or not.
Back in the early 70's I tried NGK palladium in motorcycles, didn't seem to make much of a difference over oem. This stuff has been around forever.
Today, I use the cheapy Autolites in my modern FI engine but change them regularly. Iridium in my wife's hard to get to engine.
Denso makes the GM Irridium plugs, Autolite and Champion make most of the ACDelco plugs since Delco hasn't made their own in many years, Autolite makes the splitfires and so on.
Brand recognition is almost a thing of the past.
Anyone know what the AC in ACDelco stands for?
[QUOTE Anyone know what the AC in AC Delco stands for?[/QUOTE]
Albert Champion
Started AC after he was displaced from an earlier company he founded Champion Spark Plugs
Albert Champion
Albert Champion
Started AC after he was displaced from an earlier company he founded Champion Spark Plugs[/QUOTE]
Interesting trivia! So Champion now makes Delco plugs!!
I get by with Delco R45TS very well with stock points, condensor, coil, etc. (1974 L-48).
Keeping the trivia theme; photo I took of a Champion plug on an old piece of farm equipment located on the Channel Islands, off the coast of Southern California - thought you might want a look.
Thanks for everyone’s input.
I was not really looking for power gains. Although longer life would be a nice thing.
I was more concerned about keeping the plug clean and not fouled. I mentioned this was a original short block (never rebuilt) so I do get a little build up on the plugs over time.
I have seen demos (plug manufactures) that clams a stronger spark, less prone to foul or build up.
So I am asking the forum members for their advise about the platinum or Iridium plugs from that perspective.
Thanks John
Thanks John
Thanks John
Thanks John
I always thought the fancy plugs were used in newer cars because they last longer. Some of these cars you have to use a trained monkey or take half the motor apart to be able to reach them to change them
i was always told they are a big NO-NO on most carb cars....JMO
