Anyone Tried #2357 Bulbs Instead of #1157?
The brake/turn filament is supposed to be brighter than #1157 but park/tail is the same. Only drawback seems to be about half the life (400 hours compared to 1,000). It wouldn't hurt to have a brighter brake light.
(I don't want to go the LED route.)
Wonder what the extra heat from the bulb will do to the lens after an extended operating time...might wanna check that out seeing a set is a pretty penny now a days..
c-ya
ToddG
c-ya
ToddG
Paul, I've been using 2357 bulbs, front and rear, for over five years now. I have not had a bulb burn out or any heat related problems.
The signal lights flash faster now, I assume from the increased current draw from the bulbs. Barry
I installed them yesterday in the rear along with some re-routing of the rear harness that Bubba tried. But he just tried with no cuts and so no permanent damage ensued.
I am pretty impressed. They are bright. The normal 2357 bright filament life is 400 hours but the 2357LL (Long Life) version is available at WalMart for about $3.00 a pair.
Blinkers and four-ways are functionally perfectly.
Heat? I had the brake pedal held down for about 3 minutes with a stick to seat and monitored the heat buildup. The rear lenses were warm but not hot. I am sold and will use.
Why people go fancy LED or halogen is beyond my understanding. Your choice: buy an electronic flasher with the former or burn your lenses with the latter. Or spend $3.00 on the #2357s.
You can buy your bulbs even cheaper by asking for a 10 or 12 pack. They're in a box and not fancy shrink wrap. Auto parts stores sell them to service stations like that. I bought a box of 1157's a while back for the same price as a 2 bulb pack. Try Autozone and Advance Auto Parts.
Duane
Duane
I have a 06 chevy van that is a company daily driver and it has the 2357 bulbs. This van eats light bulbs for lunch. Seems I'm always changing one out. Cant remember the last time I changed a 1157 in the vette or my 85 el camino. But then again these cars are not on the road daily
