Shift Kit
Shift Kit
I have read and listened to all th comments on the B&M Trans pack. Anyone have experience with the Transgo Shift kit? I want to order one tomorrow, and cant deciede which one. What I am looking for is a harder shift to third. It is slushy and I lose a lot of time there.
1 Post
Re: Shift Kit (SprintCarDriver)
Sprint;
I installed a TransGo kit in my TH400 when I had it rebuilt last year. I'm very happy. Be aware, however, that installing a shift kit in a transmission that needs rebuilding will be a waste of money and time. Sounds like yours may have some issues that need to be resolved before the kit is installed. Also be aware that getting the shift points where you want them may be a trial and error affair and requires changing the weights and springs in the governor. If you've had experience with automatics, you know what that entails. But if not, understand that it will more than likely require lying under your car soaking your hair in transmission fluid. If you are new to automatics, I strongly encourage you to invest in a book on TH400s. The one by Ron Sessions is a great place to start.
