Are my pistons ok?
Are my pistons ok?
Hello guys!
Well I finally got my engine after 5 long months of waiting and now I am a bit concerned. I need opinions.
The picture shows one of the pistons at the top of it's stroke. Along the area where the red dots are it just sticks out of the hole. It looks worse in the picture then it really is. At the opposite side of the dots it is just in the hole.
The engine builder said to use a gasket with a compressed thickness of .039.
Does this look and sound right?
Thank you, Marty
Thank you, Marty
You need t measure how far they stick out. Typically you'd want a quench around 0.040-0.050, so you will need a thicker gasket to get that. But many have gotten away with a tighter quench so if they don't stick out very much you could be OK. Be sure to check valve clearance.
A quick way to measure this (if you don't have a depth mic) is to take a straight edge and place it along the same line as the pin. Using a feeler gauge, measure how much above, or below the piston is relative to the block. They can be out of the hole about 0.010" before you have to worry. If they are, you can buy thicker head gaskets.
Another thing to check is the clearance between the piston and the cylinder wall itsself. If you have your pistons supplier's installation sheet, it will be listed there.
Received 1,895 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It's OK. You can measure the high side and then push down on the piston to rock it back down and split the difference. But the measurement in alignment with the wristpin is what you need.
JIM
JIM
or measure it at the pin centerline. I wouldn't worry too much, you can get head gaskets up to .060 but its up to you to pull the play doe out and check. I'm usually comfortable with .030 clearance on a 6000rpm engine
The looser the piston-to-wall clearance, the greater the piston rock. If the piston is too loose, it might not be ok with a .039" gasket, so you really need to quantify the piston deck height. As for quench, I am very happy with .035".
Hello guys!
Thank you, Marty
Thank you, Marty
*I put this on all my posts: Please post back to those who helped you, the final outcome of your initial post
Thank you all very much. I did a much closer check and pushed the high side down, it sure never moved much but your right. It is a 0 deck.
When I checked it at the wristpin it was right there. Gawd I feel good now.
I have AFR heads. Am I correct in choosing a copper ring head gasket?
When I check with the clay method, do I set the head gasket on, or without?
Once again thanks, Marty
I agree for a steel connecting rod motor I shoot for a minimum of 0.035" piston to combustion chamber clearance.
