Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2011, 07:29 PM   #1
ffvetteman
CF Senior Member
ffvetteman's Avatar
Send a message via AIM to ffvetteman
Default ZZ4 Headers?
Getting going on the ZZ4 swap into the 77 vette.
I am running the aftermarket true dual 2 1/2" exhaust that runs through the crossmember. They hook up to the sock manifolds.
Are there any headers anyone has used on the ZZ4 to an exhaust like this? I dont want to modify the exhaust since it is so new and in good shape.
ffvetteman is offline   Reply With Quote
Old 03-21-2011, 09:04 PM   #2
tonyv123
CF Senior Member
tonyv123's Avatar
When I first put a ZZ4 in my corvette, I wanted D port headers on to match the ports on the heads. I put these on
http://www.ecklers.com/corvette-head...1963-1982.html
You will have to modify the existing exhaust, but it's not costly, and easy for a muffler shop to do. Other headers will work OK, as they cover the ports, but you'll have to check which brands will cover. I really don't think you'll gain anything you'll notice with the D port headers.
tonyv123 is offline   Reply With Quote
Old 03-21-2011, 09:13 PM   #3
ptroxx
CF Senior Member
ptroxx's Avatar
Location: Rohnert Park/Sonoma Co. ca/born in NY Rockaway Beach
https://www.facebook.com/CorvetteSyndicate
when i installed my zz4, they didnt have these available they were 12 weeks back ordered... So I went with Sanderson headers(shortys)
And to be honest they almost seem like they would fit on a stock exhaust, but not sure... they are a good header at a good price.
I just sent my headers back to them to have them coated.. i got mine uncoated for the new crate motor i got..
ptroxx is offline   Reply With Quote
Old 03-21-2011, 11:05 PM   #4
1980ZZ4
CF Senior Member
1980ZZ4's Avatar
I did the Hooker Super Comps on mine. After having other header brands, Hookers are the only ones that haven't disappointed me. Expensive, but worth every penny IMO.
1980ZZ4 is offline   Reply With Quote
Old 03-22-2011, 08:21 AM   #5
Sigforty
CF Senior Member
Cruise-In IX Veteran
Sigforty's Avatar
Send a message via AIM to Sigforty Send a message via MSN to Sigforty Send a message via Yahoo to Sigforty
I ran the Jet-hot Dynomax headers on my car for a while and eventually switched out to Jet-hot coated Hooker Super Comps. I would recommend the Super Comps. They are a very good header and while the price is up there you get what you pay for. They went in with ease and did not leak like the Dynomax ones did. I also used a Earl's Pressure Master gaskets with the inserts and would recommend those as well.
Sigforty is offline   Reply With Quote
Old 03-22-2011, 08:36 AM   #6
ZZ71S
CF Senior Member
I am also using the Hookers no leaks you should go with long tubes if you want to get the most HP out of your engine.
ZZ71S is offline   Reply With Quote
Old 03-22-2011, 08:50 AM   #7
ffvetteman
CF Senior Member
ffvetteman's Avatar
Ok thanks for the info.
I am not as much looking for power gains. This is my dads car and the ZZ4 will put out more than enough power for him. We are partially looking at headers for astetics. Seems kinda weak to have that powerful of an engine with stock manifolds.
The key is I dont want to modify the exhaust if possible. Again it is fairly new and in excellent condition. The cost and trouble of modifying it is not worth it to me.
Old 03-22-2011, 04:28 PM   #8
ptroxx
CF Senior Member
ptroxx's Avatar
I think you just answered your own question..
your not going to get much of a hp gain going from stock to a header, and a header is going to need some sort of alignment to the exhaust system.. Save the header money and get your org exhaust manifolds cleaned and coated and they will look awesome..
Just a thought
Old 03-22-2011, 05:02 PM   #9
FKING1
CF Senior Member
FKING1's Avatar
Used the Hedman's on my ZZ4. They have D shaped ports made to match the ZZ4 exhaust ports.
FKING1 is offline   Reply With Quote
Old 03-22-2011, 05:19 PM   #10
ptroxx
CF Senior Member
ptroxx's Avatar
Quote:
HE is worried about his stock exhaust.. doesnt want to have to cut it..
Old 03-22-2011, 10:32 PM   #11
3JsVette
CF Senior Member
3JsVette's Avatar
I would stay away from Hedman right now. They have severe fitmit issues that more than one forum member has experienced. Ask me how I know.
3JsVette is offline   Reply With Quote
Old 03-23-2011, 04:19 PM   #12
FKING1
CF Senior Member
FKING1's Avatar
Quote:
Mine hooked up with no probs and have been perfect for past 2 yr.
Old 03-23-2011, 04:22 PM   #13
trainor
CF Senior Member
trainor's Avatar
Tim Trainor
Check out McJack's, if anybody has an exact fir it will be him. Ask me how I know?
trainor is offline   Reply With Quote
Old 03-23-2011, 08:13 PM   #14
3JsVette
CF Senior Member
3JsVette's Avatar
I know. That's why we went with Hedman in the 1st place. Unfortunately that's no longer the case. The R/S header did not clear the idler arm at all. Called Hedman Tech Line and they said it needs a "ding". Well a "ding" didn't come close more like a "smash". Then the collector angle was pointing at about a 60 degree angle to the ground so you couldn't connect the exhaust. Call Hedman back and they say "can't help you the header has been modified (dinged)". What? That's what you guys said to do! I don't know what their problem is. Quality control, manufacturing issues, what ever all I can say is the headers looked beautiful but they did not fit at all! They made no offer to help rectify the problem. Even after looking at pictures they denied it could be the product. They said it was the car. The interesting part of that conclusion is on another car the header fit the exact same way. So I guess 2 bad frames. My advise is no matter who's headers you buy make sure they fit before you do any "dinging" and if they are more than "touching" somewhere you can return them. Then find a brand that fits. I agree that almost every set of headers ends up with a "ding" somewhere but they shouldn't need more than that.
Reload this Page ZZ4 Headers?
Tags
19631982, c2, c3, corvette, dport, head, header, headers, hedman, hook, port, sanderson, swap, up, zz4, zz430
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
