Qjet carb issue
Old 03-22-2011, 09:41 PM
jez
jez's Avatar
Default Qjet carb issue
HI,
I have a Rochester quadrajet # 7043193 I think it is off a Cadillac eldorado ( 500ci) my question is will it fit my 75 Corvette ( 350ci) L82 stick shift as my carb is shot I have the original cast iron intake manifold.Hopeing someone can help as I would imagine I would need to rejet the carb right? thanks
Old 03-22-2011, 09:47 PM
'75
'75's Avatar
If you email Lars at v8fastcars@msn.com you will get solid advise.
Old 03-22-2011, 10:51 PM
Rusty-one-1
Rusty-one-1's Avatar
This web site may help
http://home.earthlink.net/~quadrajet...ow_ratings.htm
Old 03-23-2011, 07:16 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Yes. Basically, it is a rejet and rod deal. There are some other subtle issues that should be addressed (linkage connections, fuel line change, configure it for manual tranny if necessary, reset secondary air valve rate, mounting spacer/heat plate, etc.), but the carb will work fine on your engine.
Old 03-23-2011, 08:52 AM
noonie
noonie's Avatar
Check your numbers again and post a pic if you have it.
Don't have the specific listing for that one, but it shows as a 2 barrel for a non GM application use like marine or school bus etc.
If it really is a 2bbl, then it won't fit the stock vette intake.
Old 03-23-2011, 03:50 PM
Roadking
Support Corvetteforum!
Roadking's Avatar
I had just used this site and it worked for me.
http://www.cliffshighperformance.com...carb_ID_2.html
Old 03-23-2011, 08:48 PM
kdf1986
kdf1986's Avatar
Another check would be the side bowl fuel inlet. Some Q-jets used a front bowl fuel inlet. It would still work on your car, but you would need to fabricate a new fuel line from the pump to the carb inlet.
kdf
To Qjet carb issue
Quick Reply: Qjet carb issue
