You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
My small block was running great. So I decided to do a cam change and tear it apart. I wanted to check the timing marks from the previous owners build. So I did the following.
1. Marked #1 plug on dist. base and removed cap.
2. Rotated crank until rotor pointed at #1 (confirmed compression) then put the mark on the balancer at zero on the timing tab.
3. Removed the timing chain cover.
Now at this point I was expecting to find the crank dot at 12 o'clock and the cam dot at 6 o'clock. That did not happen.
The crank was at 12 o'clock AND them cam sprocket was also at 12 o'clock.
When I line them up at 12 and 6 the rotor points at #6.
Dot to dot is TDC but NOT the compression stroke. To time the engine I need to rotate it 180 so that its crank 12 o'clock and cam 12 o'clock and that will be TDC on the compression stroke.
Location: about an hour away from Paul74 in Ontariariario
Quote:
