all pictures of 700r4 install
700r4 install…..this is it in pictures, lots of guys are asking about this and there is lots of info out there on doing this so this is just the picture version.....i have 350 hp, 425 ft lbs 355, with a 3.06 rear end and 2500 stall converter...true 2.5 duals no cats and an H pipe, the H pipe provide more low end torque when yu are in lock up at 1100 rpm....i am sure an x pipe would do the same....i also have a manual lockup switch that will unlock the converter mounted in the extra hole next to the headlight override switch
I sourced everything mostly from BTO. let me get all photos in then i will add narrative if you see a red X just right click on it and "open picture" all the links are good
Total package
Replacing solenoids in trans
Drilling out shift detent
these detents are accidentally flipped backwards in the photo
Cross member
Shortened drive shaft
Trans with pressure testing gauge on it
Clearance is tight on a 77
Wiring up brake switch and lock up
Cable bracketry the TH350 does not line up with the holes....so i made one then realized the shiftworks kit came with one
Crap I hate when that happens
Shift lens
pictures of TV linkage on Carb
(need to dig for these)
Total package
Cross member
Shift lens
oh yeah that was 18000 miles and 6.5years ago.....i just saw the same questions coming up and thought it would be a good time to let people see whats involved in doing the swap in pictures
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Thanks bob, this is a big help. Unknowingly, you just became a resource for me to nag the hell out of with more questions later on this summer...
these are 04 prices
drive shaft shortening $85
tv kit, bracket cable, cross member, pressure gauge, relay circuit, shift detent $542
torque converter ( i cant find receipt) estimated $300
used trans $300
used trans $300
1 Post
I'll be in touch later this summer for tech help, I'm sure. thanx.
i went with the engineered kits because at that momenmt i had the money but not the time.....if you had the time you could have created everything except for the TV bracket and cam which was about $110
thanks for the price list. I have found a good deal on a 2004R but I'm kinda skeptical about buying a used tranny that is out of the car. I want to go the 200 route because I now have a TH400 so it should bolt right in.
they have many internal faults/weak spots that will NOT be good for any high performance use....
the sun shell, is one for a couple hundred right there,
I built one what I hope if grenade proof....for a 8000 gvw motor home, class C.....
