You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
I routinly use the ZZ4 rotating assy as a replacement engine for many marine applications. Absolutly no problems with these engines. We found the brand new ZZ4 rotating assy to be no more money than a reconditioned engine. Good luck Al
I put one in my 71 back in 2002. It was a great engine up until the car went under in Katrina. I would definitely use one again. The best thing is the cost for an engine with a roller cam setup.
I put one in my '91 Z28 back in 1998 and topped it off with the stock TPI set up. It was perfect. I put 70,000 hard miles on it over the next few years, swapped heads on it a few times. Swapped cams and intakes a few times. Never 1 problem with the motor at all. I highly reccomend them to anyone wanting a replacement GEN1 small block.
The roller lifters, 1 piece rear main seal, and o-ring-type plastic timing cover are all far superior to the what came in our C3s originally.
I just put one in my 75 Coupe and I love it. I put headers on it and Magnaflow mufflers and it sounds great too! I would definitely choose that engine again.
I put one in my 71 about three years ago dropped wright in place of the stock engine no major modds needed.
If you want some more power in the future there are lots of proven combos ready to bolt on.
Yes you'll need a new flywheel, as the ZZ4 comes with a flexplate. If you use the search box here, there is alot of good write-ups of people putting a ZZ4 in a C3.
Thanks for the info.the guy I bought mine from rebuilt the original engine but rather than hop it up and take a chance with it I think would rather pickle it and put a new one in it.
Ditto. The ZZ4 in my '75 has great torque and pulls hard and smootly through all four gears. Long tube headers and true duals with Magnaflows also. You won't be disappointed.
Terry
I put a Fast Burn 385 HP and 385 Ft Pds Torque. It is a ZZ4 bottom end with better heads. Motor is fantastic, a lot of power for me, and runs cool with AC on.
5 speed Keisler TKO is one of the best features for the money.
Location: Rohnert Park/Sonoma Co. ca/born in NY Rockaway Beach
Quote:
Originally Posted by TopGunn
I think it's a great engine and runs like a top. I was disappointed with the power, changed the cam and heads and it's much better to me now.
I would have to agree... I jsut did the ZZ4 in mine, ANd I sure wish I should have done the LT-4 hot cam package with it..
I have even thought maybe the 383fast burn was the way to go..
It was just a little light on the HP for me.. I dyno'ed at 260 ..
I have shorty headers, 2.5 all the way with magnaflow, curved dist, and built carb.. And I just wish I had about another 50-75
Oh well ... i plan on the cam swap here soon.with a 200r swap as well..
I put a ZZ4 in my 80. I love it. Also it was one of the very few crate engines I could find that would fit under my stock hood. That 383 has a higher rise intake that won't fit. Even with the ZZ4, I need a drop-base air cleaner and now it just barely clears the hood. Of course you can get a big block hood for more clearance, but that's another $600-700.
