Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-20-2011, 11:29 AM   #1
my75baby
CF Senior Member
my75baby's Avatar
Default SBC 400 - one rocker nut keeps loosening ?
Hello all I need a motorhead to answer this one, I recently replaced the cam, rocker arms, nuts and lifters on my SB 400. However one rocker arm nut keeps loosening up and I do not know why. I tighten it (adjusting the valve properly) and then drive the car for a while only to find it loosens up and starts clacking again. Anyone ever experience this before? I figure when the hydraulic lifter is properly loaded it would prevent the nut from loosening, but it keeps doing it.. any ideas?
my75baby is offline   Reply With Quote
Old 02-20-2011, 11:41 AM   #2
7t9l82
CF Senior Member
Support Corvetteforum!
7t9l82's Avatar
do you have pressed in studs? if you do a high lift cam will pull them up. was a common problem years ago. otherwise, poly locks should help
7t9l82 is offline   Reply With Quote
Old 02-20-2011, 12:04 PM   #3
CA-Legal-Vette
CF Senior Member
CA-Legal-Vette's Avatar
Even if you have threaded rocker studs, check the torque and make sure that it isn't coming loose. I had a chronic problem with my stroker. All it took was 8 globs of Loctite red and the problem went away.
CA-Legal-Vette is online now   Reply With Quote
Old 02-20-2011, 12:43 PM   #4
my75baby
CF Senior Member
my75baby's Avatar
LOL.. thanks guys, I was thinking about threadlocker on this particular nut, just didnt think you were supposed to use that on rocker studs.. but it MUST stop doing this. I was almost going to double nut it
Old 02-20-2011, 12:46 PM   #5
Vette5.5
CF Senior Member
Been awhile, but last build I did used longer rocker arm nut's with allen type jamb screw's on top. Not really sure where I got these, but running a high lift cam, and nothing's moved.
Vette5.5 is offline   Reply With Quote
Old 02-20-2011, 12:57 PM   #6
Manuel Azevedo
CF Senior Member
Manuel Azevedo's Avatar
Quote:
A couple things here, but are you sure the nut is backing up? As said make sure the stud is not getting loose or pulling out. Does the nut feel loose when you re-adjust? And the worst one check and be sure the rocker is moving the same amount as the others, (lobe going flat)
Manuel Azevedo is offline   Reply With Quote
Old 02-20-2011, 02:32 PM   #7
midyearvette
CF Senior Member
midyearvette's Avatar
Quote:
there ya go!......
midyearvette is offline   Reply With Quote
Old 02-20-2011, 02:49 PM   #8
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
There is may be one thing a 6 sec man not might be aware of. Cheap CHinese push-rods being manufactured under legit US companies. Do these push-rods have the little ***** on the end of them ?
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage......................................My'70 CUDALotsa ladies and lotsa trouble
MotorHead is offline   Reply With Quote
Old 02-20-2011, 03:12 PM   #9
Les
CF Senior Member
Les's Avatar
I'd mark the nut and the stud, then check to see if the marks are still aligned when it starts clacking again. If they still match up you know the problem is one of the other things mentioned.
__________________
08 Jetstream Blue Z06 w/ Comp Grey wheels & 2LZ- and LeMans Blue 69 coupe, original 427(now 439), L88 hood, forged alum. pistons(9.5 comp), Barry Grant Holley DP, Edel. Perf. RPM Airgap intake, Edel. Perf. alum. heads, Ultradyne solid flat tappet cam(243/251 @.050,.586/.601 lift) Jet Hot coated Hedman headers, mandrel 2 1/2" exh. w/ Dynomax Ultraflos & X pipe, TH400 w/ B&M cooler, Continental 2600 RPM stall TC, 3.55 gears, QA1 adjust. shocks, MT ET Street Radials, 1/4 mile in 11.37 @ 119.7 MPH
Les is online now   Reply With Quote
Old 02-20-2011, 07:36 PM   #10
my75baby
CF Senior Member
my75baby's Avatar
All very good suggestions guys, thank you. As for the cam, it is brand new so it has not had time to wear a lobe down. It is either loosening or, as stated, I am pulling the stud out of the head. If that is the case, is there a way to put a pressed stud back in the head without taking the head off?
Old 02-20-2011, 08:09 PM   #11
Manuel Azevedo
CF Senior Member
Well it may not be a lobe thats why to check everything. But a new cam is the most vulnerable to going flat.
Old 02-20-2011, 08:16 PM   #12
alswagg
CF Senior Member
Well this is what happened to one of our engines. First off, 383, Vortec heads, CJ 7. Son floated valves at 7k+ rpm while in a snow bank last winter. I notice a rocker noise. I tightened the rocker, noise came back after about 3 minutes of running around 3k rpm. I measured the stud height, sure enough #2 exhaust stud pulled. Here is a bubba fix, temp to perminate. I just removed the rocker assy, and reinstalled the nut flush with the stud. I then smacked the stud with ball peen hammer. lol I made sure the stud was level with all the others using a straight edge. At this time I reinstalled the rocker assy and tightened as needed. That was over a year ago and no problems at all. I figured it would pull back out but has not. Some my flame me, but $0 cost and it worked. Heck I did not even have to replace the cover gasket due to it being the new rubber type. Try it, worst case it does not work and you have to have a new stud installed. Al
alswagg is offline   Reply With Quote
Old 02-20-2011, 08:22 PM   #13
my75baby
CF Senior Member
my75baby's Avatar
Very true Manuel, however this is a totally stock cam, used molykote on lobes and lifters and break in oil, and when I tighten it down its fine and car runs great. I am doing the opposite of what most guys do on here, I am building more of a driver than a racer. Have a 600cfm Edelbrock with stock cam, I want no lub at all, just smooth. Stock T10 with stock clutch. The car runs beautiful with no shaking or vibration and is a blast to drive. I will be quieting down the exhaust as well. I know its blasphemy... but car is still pretty quick with the 400 in it. If I want to go fast, I will just drive my Jag, (that one has the supercharged motor and is crap your pants fast,, LOL)
Old 02-20-2011, 08:26 PM   #14
7t9l82
CF Senior Member
7t9l82's Avatar
this is why all of the high performance Chevy's had screw in studs
Old 02-20-2011, 09:28 PM   #15
my75baby
CF Senior Member
my75baby's Avatar
Well if the stud worked its way out I will just tap it back in like Al said, does anyone think double nutting it will work if its not the stud and just a nut loosening?
Old 02-20-2011, 09:50 PM   #16
DRIVESHAFT
CF Senior Member
DRIVESHAFT's Avatar
Double nutting will work. But if your nut is actually backing off, its just worn out. You can buy replacement rocker nuts fairly cheap.
DRIVESHAFT is offline   Reply With Quote
Old 02-20-2011, 10:03 PM   #17
snoopykissedlucy
CF Senior Member
snoopykissedlucy's Avatar
Send a message via Yahoo to snoopykissedlucy
My own experience:
rebuilt a 350 with a new Edelbrock cam, heads, gaskets.
Set the hydraulic lash 1/2 turn past....cranked engine up over 2200 for 30 minutes.
It ran crappy. Pulled the valve covers.......one rocker was loose. I tightened and repeat.
Same thing, same rocker loose. Tightened again.......same result.
End of the story.........one lobe on the new cam was wiped down immediately at start-up. Edelbrock agreed to ship another cam free of charge(they rule).
snoopykissedlucy is offline   Reply With Quote
Old 02-20-2011, 10:45 PM   #18
my75baby
CF Senior Member
my75baby's Avatar
Thanks Driveshaft, these are new nuts though.. Hey snoopy this cam is not an Edelbrock, and it better not be wiped.. I think its just loosening up it really does run great.. even when loose.. just clacks...
Old 02-20-2011, 10:53 PM   #19
mds3013
CF Senior Member
mds3013's Avatar
Have you put a straight edge across the studs to see if it has pulled? I am hoping it has not. mike...
mds3013 is online now   Reply With Quote
Old 02-20-2011, 11:16 PM   #20
my75baby
CF Senior Member
my75baby's Avatar
I will try that tomorrow.. not much I can do if it is.. just try to tap it back in square with a ball peen.. if not I guess I have to pull the head..
Reload this Page SBC 400 - one rocker nut keeps loosening ?
Tags
350, arms, backing, chevy, corvette, drive, lifter, loose, loosen, loosening, loosing, nut, nuts, rocker, sbc, studs, threadlocker, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
