My exhaust heat shields
I decided to try and shield the floor of the car from the radiant heat from the exhaust pipes. I didn't want to drill holes in the floor so I tried a different aproach. I made the shields with brackets that I could clamp to the pipes with hose clamps. Really easy to make and installed in about ten minutes.
Jack
Jack
Best heat reduction improvement I made was to install the Thermo Tec self adhesive product under/behind my two lower factory front heat shields. Cut it to fit after making a pattern. Also installed the product under the two floor pans.
http://www.thermotec.com/products/13...t-barrier.html
Put some insulation material between the pipe and those covers and they will do great. If no other product like that is on the market, you should patent them and sell them to the aftermarket suppliers.
