Head Gasket question
Is that the one that is not for use with aluminum heads?
For the thinnest, I'd go with the FelPro 1094 which is good for cast iron or aluminum heads. BUT, before you jump for this .015" thick gasket, check you quench height (deck clearance plus gasket thickness) first to ensure that there is a minimum of .035"! YMMV
