Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2011, 11:33 AM   #1
7T3C3TTZ07
CF Senior Member
7T3C3TTZ07's Avatar
Default What Causes Valve or Valve-Spring Breakage?
Several years ago 4-bolt 350/350 with 75,000 miles was turned over to an engine shop to be refreshed with a "hotter" hydraulic cam and a little higher compression ratio. After the rebuild, I experienced a broken valve spring and a broken valve while driving (OK WOT hot rodding) it in a fashion similar to before the rebuild. The shop repaired everything and touched up the valve seats at their cost. I think that the rebuild must have weakened the engine in some way.
For a different C3 with an L48 I am considering having an engine shop put in a stroker kit, new cam and increase the CR with new heads. I want to make sure that I do not weaken this engine. I don't want to revisit broken valves springs and other parts. I am curious as to the possible root causes and preventions for broken valves and springs apart from leaving it stock or driving it like it is a hearse.
A ZZ383 would be more than stroking the L48 work but I may opt for that to avoid problems.
Thanks,
Ken
7T3C3TTZ07 is offline   Reply With Quote
Old 02-02-2011, 11:45 AM   #2
Sigforty
CF Senior Member
Cruise-In IX Veteran
Sigforty's Avatar
Send a message via AIM to Sigforty Send a message via MSN to Sigforty Send a message via Yahoo to Sigforty
It is hard to say, but I would think that the spring that broke was weak and could not handle the new cam. If you are considering a cam swap, always look at matching the valve springs to the cam. Often broken springs could not handle the pressure and either weak or undersized for the cam lift.
Sigforty is offline   Reply With Quote
Old 02-02-2011, 11:52 AM   #3
Gordonm
CF Senior Member
Gordonm's Avatar
Broken valve springs have nothing to do with a stroker engine at all. The broken springs are usually a mismatched spring for the cam. Usually coil bind is a reason or to weak a spring for that particular cam causing valve float. I would never put in a new cam without at least checking the spring pressure but Iwould replace them as my first choice. Springs are cheap. You will not "weaken" the engine by doing modifications. The only thing that happens is mismatched components that are not up to the task of more HP and rpm. Get it right the first time and you will not have this problem.
Gordonm is offline   Reply With Quote
Old 02-02-2011, 12:24 PM   #4
JE Caudle
Junior Member
JE Caudle's Avatar
I'm sure Gordonm answered your question correctly.
If you are willing to fork over the money for a ZZ4 you could have
430hp at your finger tips.
1) ZZ4 short block
2) LT4 hot cam
3) Fast Burn 385 Heads
4) 1.7:1 roller rockers
5) 750 Holley
Rock and Roll...
JE Caudle is offline   Reply With Quote
Old 02-02-2011, 12:39 PM   #5
gkull
CF Senior Member
gkull's Avatar
If you end up with broken valve springs and like this other poster found that he had the wrong oriented pistons in some of the cylinders. The reason is Morons maximizing profits on the rebuilds.
gkull is offline   Reply With Quote
Old 02-02-2011, 12:48 PM   #6
midyearvette
CF Senior Member
Support Corvetteforum!
midyearvette's Avatar
Quote:
..good post but you have to remember, there are more JUNK new parts out there now than ever before...you must by quality stuff and that usually means more $$........
midyearvette is offline   Reply With Quote
Old 02-02-2011, 12:54 PM   #7
Gordonm
CF Senior Member
Gordonm's Avatar
Quote:
I agree on the parts. Make your selection carefully with quality parts. Speed is never cheap.
Old 02-02-2011, 05:36 PM   #8
jb78L-82
CF Senior Member
jb78L-82's Avatar
I had a spring break on my totally stock L-82 with 35,000 miles in 1986 on it cruising down the highway at 70 MPH!
jb78L-82 is offline   Reply With Quote
Old 02-03-2011, 07:08 AM   #9
gkull
CF Senior Member
gkull's Avatar
Quote:
You should not have waited 35,000 miles before you changed your oil or checked the level!
Old 02-03-2011, 09:03 AM   #10
jb78L-82
CF Senior Member
jb78L-82's Avatar
Too funny-LOL!!
Just cruising down the highway at 70 MPH and then started to feel an engine vibration. Stopped at the toll booth that was about 1/2 mile away when the vibration occurred and the engine would barely idle. Limped it home for another 10 miles, pulled valve cover, and presto stock valve spring on stock engine broken-secondary valve spring held the valve up. Replaced it and never had a another problem. I do think that the insane OEM engine temperatures that the L-82 used to run from the factory (225-240 degrees) might have contributed to metal fatigue. Engine runs about 175 degrees today!
Old 02-03-2011, 10:48 AM   #11
jackson
CF Senior Member
....The broken springs are usually a mismatched spring for the cam. Usually coil bind is a reason or to weak a spring for that particular cam causing valve float.....
and water temp has little to do with spring life ... oil temp does ... but primary cause for broken spring is spring mismatch & coil bind ... just as Gordon says
jackson is offline   Reply With Quote
Reload this Page What Causes Valve or Valve-Spring Breakage?
Tags
2011, break, broke, broken, c3, corvette, engine, engines, nat, spring, springs, tech, valve, valvesprings, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
