Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2011, 09:32 AM   #1
USMuscle
CF Member
Default 1977 Corvette L82 - Engine Questions
Just picked up a 77 L82. It has a little oil leak which looks like it is coming from the main seal. Is this a common issue? Easy fix on these cars?
Thanks!
USMuscle is offline   Reply With Quote
Old 02-01-2011, 09:43 AM   #2
Mastr Fab
CF Senior Member
Front or rear main seal?
Mastr Fab is offline   Reply With Quote
Old 02-01-2011, 10:06 AM   #3
USMuscle
CF Member
Quote:
Looks like the rear. The leak marks are strongest right between the oil pan and tranny (just behind the oil pan).
Old 02-01-2011, 02:06 PM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Almost any smallblock will eventually leak from the main seals. I'm betting the seals in your '77 are original and 30+ years old.
Easy Mike is offline   Reply With Quote
Old 02-01-2011, 02:46 PM   #5
SOMFormula
CF Senior Member
Quote:
Thanks!
Nice! post up some pics, hahaha.
Its easy. Just take your time. There are some good write-ups on it. I like to use Permatex Anerobic gasket sealer, myself. Its about $6 a tube at Napa's. Its located in the Loc-tite/sealant/glue sections. Also, spring for the Fel-Pro Perma-Dry pan gasket. It has crush washers and its re-usable. so if you messed up your RMS install, you can always drop the pan again and not have to worry about buying another gasket. Also, Fel-Pro RMS gaskets come with the little tool for install that is very helpful.
You only need motor oil to lubricate the rear main bearing upon install.
Let the motor oil drain from the pan overnight...you'll thank me for that advice, hahahahaha.
SOMFormula is offline   Reply With Quote
Old 02-02-2011, 02:34 PM   #6
scottyp99
CF Senior Member
scottyp99's Avatar
That Fel-pro gasket is AWESOME!!!! Much easier than old-school pan gaskets.
Scott
scottyp99 is online now   Reply With Quote
Old 02-02-2011, 03:09 PM   #7
thegazman
CF Senior Member
thegazman's Avatar
Default thegazman
Look at the "Vettetech" web site under misc. they have a detailed article on replacing the rear main seal without pulling the engine. Lots of photos.
thegazman is offline   Reply With Quote
Old 02-02-2011, 05:00 PM   #8
jb78L-82
CF Senior Member
jb78L-82's Avatar
I have owned my 78 L-82 4 speed since 1983 when I bought it with 25,000 miles on it and the rear main seal leaked just about from day one. I finaly have tired of the leak and I will be be replacing the rear seal and the front time chain seal in the spring. I bought the Fel Pro rear main seal, a new 1 piece Fel Pro oil pan gasket with the reuseable feature, a new comp cams double roller timing chain and gears (I believe that I have a nylon chain and gears from the factory), a new Fel Pro timing case gasket and front seal, and a new melling standard oil pump (since i am there anyway) as well as new lower Moog ball joints (since I have to separate the front steering linkage to remove the oil pan. Should be great fun LOL! I will check out the vettetech article in the misc section before I begin. Thanx.
jb78L-82 is offline   Reply With Quote
Old 02-02-2011, 07:46 PM   #9
my 76 ray
CF Senior Member
my 76 ray's Avatar
Quote:
FYI You do not have to separate the ball joints to drop the steering linkage.
my 76 ray is offline   Reply With Quote
Old 02-02-2011, 08:18 PM   #10
my 76 ray
CF Senior Member
my 76 ray's Avatar
I uploaded some videos of a rear seal replacement on my Jeep. It's a 6 cylinder but it has a two piece rear seal and the process for replacing is the same as a Chevy 350 with a two piece seal. It was shot as I did the replacement and it wasn't scripted, I was just talking as I went. I hope it helps.
http://s413.photobucket.com/albums/p...20replacement/
Old 02-03-2011, 12:29 AM   #11
sly vette
CF Senior Member
sly vette's Avatar
Quote:
Yep...
I think you only need to remove the idler arm from the frame.
__________________
Later,
Sly
sly vette is offline   Reply With Quote
Old 02-03-2011, 09:06 AM   #12
jb78L-82
CF Senior Member
jb78L-82's Avatar
Guys, I checked the Vettetech recommendation above and noticed that as well about removing the idler arm and not the passenger side lower ball joint but the article mentioned removing the starter which another article I read said if you remove the idler arm and the pass side lower ball joint, you do not need to remove the starter. Any thoughts?
Old 02-03-2011, 03:19 PM   #13
allend43
Junior Member
You do not need to remove the ball joint, but removing the starter, you will be able to get to the rear pan bolts easier on that side.
allend43 is offline   Reply With Quote
Old 02-03-2011, 04:01 PM   #14
mikep3
CF Senior Member
mikep3's Avatar
Default Disconnect the Battery
Disconnect the battery,
Drain the oil and remove oil filter,
Drop the starter,
Remove the transmission cover plate,
Drop the steering cylinder,
Drop the idler arm,
Remove the oil pan bolts,
Clean the engine were the new seal will go,
Use a one piece seal for 79 corvette 350,
Check oil pump inlet for popper depth to new oil pan,
Install new seal with sealant in the corners only,
Install pan,
Install steering cylinder,
Install idler arm,
Install transmission access cover,
Install starter,
Fill with new oil and new oil filter,
Connect battery,
Did I mention to Disconnect the Battery, the Starter is very Hot!
mikep3 is offline   Reply With Quote
Old 02-04-2011, 09:58 AM   #15
fauxrs
CF Senior Member
fauxrs's Avatar
Its a damn sight easier to remove the starter than a balljoint, and in any case it will be alot easier to get to the oilpan bolts with the starter out of the way.
fauxrs is offline   Reply With Quote
Old 02-04-2011, 10:15 AM   #16
speedreed8
CF Senior Member
speedreed8's Avatar
i would use a double lip offset seal, you may have a wear mark on the crank, and another single lip seal will leak again.
http://www.oreillyauto.com/site/c/de...2303&ppt=C0026
i recently changed mine to a double lip offset, 79, new engine, but engine builder of shortblock installed a single lip, and all i had to do was drop the steering link attached to the passenger side frame, then the pan will come right off. didnt remove starter.
i do have dual exhaust, so i didnt have to mess witht he exhaust pipes. 2 hr. job. with the felpro 1 piece pan gasket
speedreed8 is offline   Reply With Quote
Old 02-04-2011, 01:07 PM   #17
jb78L-82
CF Senior Member
jb78L-82's Avatar
I bought that seal too! I too have a dual exhaust and plan on removing the pan without removing the starter as well. Thanx.
Reload this Page 1977 Corvette L82 - Engine Questions
Tags
1977, 77, back, calif, chevrolet, corvette, engine, l82, leak, northern, oil, price, rear, replace, rh, seals, side, starter
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
