1980 corvette steering - speedometer
I bought 1980 corvette coup last march and have been fixing issues since. Fortunately nothing major, two probelms left.
Speedometer and cruise not working, cables and gear wheel in trans ok. Just installed new transducer still does not work.
Steering wanders a little at speeds over 50 mph. front lower control are bushings replaced. Two mechanics say other bushings front and rear ok.
help
help
If the bushings and linkages are good the two most likely culprits are the rag joint and the steering gear. If there isn't much play in the steering when the car is stationary, the steering gear is the more likely. Both these issues are common. If the rag joint, just replace it. If the steering gear, it will need to be rebuilt. It can be done at home but you may be better off having it done, if for no other reason than you'll need a speacial torque wrench which will cost you more than the rebuild.
Yes you need to get this fixed, my 1980 just took off to the right anytime you got above sixty, talk about needing to change your undies, Both rag joint & box needed replaced. When I rebuilt my 82, I just replaced everything. No problems, thus far, but like CA-Legal-Vette said; C-3 need lots of tender loving Care. Have a great one. Gene
