Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-10-2002, 11:56 PM   #1
Golden80
CF Senior Member
Golden80's Avatar
Default How do I adjust the shift-point's in my TH-350?
Is this something that can be done by adjusting a bolt or a cable? And does the tranny have to be opened or pulled to do this? I'd like to adjust my shift point down about 500-800 RPM's because the engine quits after about 3600 RPM's.
Thanks,
Matt
Golden80 is offline   Reply With Quote
Old 04-11-2002, 12:50 AM   #2
Magic Fingers
CF Member
Magic Fingers's Avatar
Default Re: How do I adjust the shift-point's in my TH-350? (Golden80)
First , if your engine is done @ 3600 RPM, shift point should be @ 3800 RPM, to stay within your power band. That is if you are talking about wide open throttle shift points. B&M makes an adjustible shift governor kit that only requires removing the shift governor cover, changing springs and weights to your desired shift points, and you're gone. I taylor these for people at the drag strip in about 10 minutes. I own a 70 Buick GS 455 Stage 2 that runs 10:50s in drive without having to shift. Manual shifting showed no improvement. Plus the car is brutally consistant. Don't get me wrong, it takes some playing with to get the right combo of weights & springs, but its worth it . Keep a record as you chart shift points, as in colors of springs-weight numbers,to shift point. E-mail me if you want more info, or call me at my new shop (THE SHARK SHOP) , specializing in '68-'82 Corvettes. 414-281-2029
Magic Fingers is offline   Reply With Quote
Old 04-11-2002, 07:28 AM   #3
jerryp58
CF Senior Member
jerryp58's Avatar
Send a message via AIM to jerryp58
How abaout an adjustable vacuum modulator?
I got one for my TH350 from Advance Auto for about $12.
It's just a "tin can" on the front passenger side of the trans that has an adjusting screw to move the shift points up or down the RPM range.
jerryp58 is offline   Reply With Quote
Old 04-11-2002, 07:55 AM   #4
Matt Gruber
CF Senior Member
Default Re: How do I adjust the shift-point's in my TH-350? (jerryp58)
have you tried adjusting your foot? let up for 1/2 second and it will shift.
Matt Gruber is offline   Reply With Quote
Old 04-11-2002, 05:47 PM   #5
jerryp58
CF Senior Member
jerryp58's Avatar
Default Re: How do I adjust the shift-point's in my TH-350? (drives61)
"let up [off the gas] for 1/2 second" -- NEVER!
BTW, how was your "TH400 recalibrated to shift at 5700 in D"?
Jerry
Old 04-11-2002, 09:07 PM   #6
Matt Gruber
CF Senior Member
jerry
MagicFingers described it above. Kit cost $28 from B&M. very easy to do. i got lucky and got it on the first try.
Golden80- just twitch your foot until you get around to fixing it. Clogged cat? fouled plug? bad wire? worn out? No good running c3 shifts below 5000 floored.
Old 04-11-2002, 09:21 PM   #7
Aaron76
CF Senior Member
Aaron76's Avatar
Am I missing somthing here
When I stomp on it mine shifts at 5000 or more or are you guys talking about crusing acceleration.
Aaron76 is offline   Reply With Quote
Old 04-11-2002, 11:08 PM   #8
Chris O'
CF Senior Member
My stock L48 shifted at 4500 until I got the heads ported and bigger valves and Perf manifold. Shifts at about 5400 now. :)
Chris O' is offline   Reply With Quote
Old 04-12-2002, 11:47 AM   #9
theandies
CF Senior Member
theandies's Avatar
Location: "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
Default Re: How do I adjust the shift-point's in my TH-350? (Chris O')
If your engine's power is dying at 3600 RPM, I'd fix that first. Do a tune-up or better yet get a bigger cam and do some performance upgrades. This will do more than changing your shift points. Thats just my opinion.
John
theandies is offline   Reply With Quote
Old 04-12-2002, 01:14 PM   #10
Golden80
CF Senior Member
Golden80's Avatar
Default Re: How do I adjust the shift-point's in my TH-350? (theandies)
The engines got over 100K on it and is getting tired. I just want to play with it at the dragstrip on Saturday to see what it will pull so that I'll be able to compare it to my ZZ4 when I get it next fall.
Matt
Old 04-12-2002, 09:46 PM   #11
theandies
CF Senior Member
theandies's Avatar
Gotcha, love the sig.
John
Old 04-12-2002, 10:39 PM   #12
SUPERTECH
Junior Member
These guys are drunk ,Adjust your detent cable(kick down cable)Sounds like its to tight it should only hold your shift down at wide open throttle thats WOT for you MR. ASE mastertech1984.
Mark H
1998 ASE master tech :smash:
SUPERTECH is offline   Reply With Quote
Old 04-12-2002, 11:37 PM   #13
jerryp58
CF Senior Member
jerryp58's Avatar
Default Re: How do I adjust the shift-point's in my TH-350? (SUPERTECH)
I haven't been drunk for 26 years :cheers:
I'm not a master tech, but are you thinking that he's not shifting at all at WOT? It sounds like the problem is not that the transmission isn't shifting, but that he wants to change the shift point from around 4100-4400 RPM to 3600 RPM. Yes/No :confused:
Old 04-13-2002, 12:10 AM   #14
Golden80
CF Senior Member
Golden80's Avatar
This was all at WOT.
Well I found why it was dying after about 3700 RPM. Before today it would get up to 3700 and then stop accelerating. It would not get into 2nd unless I'd let off the gas. Needed a new air filter and a carb tune up. The cars pulling good to 4500 now. The yellow line on my tach is at 4500 for the 305. I adjusted the float a little and also adjusted the mixture control solenoid since it's a computer controlled QJet. But I think the big thing was the new air filter. The old one was pretty grungy and don't worry...I slapped myself for not changing it sooner. The car feels a heck of a lot better since it can breathe now.
Matt
Reload this Page How do I adjust the shift-point's in my TH-350?
Tags
1985, 350, adjust, corvette, hydramatic, performance, point, points, rpm, setting, shift, th350, transmission, tune, turbo, turbohydromatic
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
