Body Lift Help
Old 01-22-2011, 11:33 AM
PUNISHER VETTE
PUNISHER VETTE's Avatar
Default Body Lift Help
I been informed that to properly fix my body mounts on my 69 coupe i'll need to do a body lift. I have some questions for starters about the easiest method that I'll be able to do it by myself as I have nobody to help.
I was planning on an engine hoist and body straps... But i only have a 9ft ceiling(still possible?)
I've been compiling links to other members restorations/body lifts for ideas and information and so far so good.
http://www.cardomain.com/ride/565523...orvette/page-8
http://forums.corvetteforum.com/c3-t...checklist.html
http://vettemod.org/index5.html#
http://corvetterepair.com/services/tech-tips/
http://coopersgarage.piczo.com/1973c...linkvar=000044
http://www.corvette-restoration.com/...dy_removal.htm
My interior is already gutted so that's done. I'd like to leave the engine and gas tank in place...
Old 01-22-2011, 11:34 AM
PUNISHER VETTE
Here is a picture of my garage so you know what i'm dealing with.
Old 01-22-2011, 01:01 PM
mysixtynine
mysixtynine's Avatar
My ceiling is only 96"s tall so you have a little more room than me. Its not impossible to do on your own. Really helps to have another set of eyes at least. The gantry crane and body cradle below would be the most reliable and easiest to use by yourself. Still need someone just to keep an eye on you when lift heavy stuff.
I used my cherry picker and made up my own cradle out of wood as the lifting straps I had were way to long. Mind you the wooden cradle was only designed to keep the strap apart and away from the body so they are only dealing with compression loads. It is not lifting the body itself.
Cherry picker body lift
I have since picked up a steel body cradle from accessiblesystems.com and my body strap kit that can be used lift the body all on its own and I use a gantry crane from harbor freight. The gantry crane is too tall for my garage without poking holes into the ceiling (which i will do anyway) but the picture below is from my budys garage where we used it to lift the body. You can use the cradle on the cherry picker as well.
body cradle
Old 01-22-2011, 04:57 PM
PUNISHER VETTE
Well I started prep for the body lift today.
So far what's done:
-Interior is gutted(seats, carpet, console, steering wheel...)
-hood is off
-front bumper and grille removed
-radiator removed
-master cylinder lines disconnected
I'm going to need some help with descriptions of parts as I don't know what they look like and they're telling me to take them off... maybe they're not for my year car and that's why i'm confused. If anyone has a photo of any of these that would be awesome.
-Clutch Rod Wire Clip(supposed to be under the master cylinder...?)
-Back-up Light Plug(supposed to be behind the distributor...but so are a billion other plugs)
-Accelerator Rod and Ground Strap(is the rod necessary for a body lift? or did they throw that in for a engine lift as well?)
Old 01-22-2011, 05:50 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi pv,
I'll take the back-up light connection.
Find the switch on the transmission and follow it under/through the tunnel and up the engine side of the firewall. You'll come to a plug-connection that allows the switch to stay on the transmission when you lift the body.
Regards,
Alan
Now the clutch rod clip.
The clutch rod comes through the firewall under the master cylinder. It connects to the z-bar that goes across the frame and then down to the clutch arm. The clip holds the rod that comes through the firewall to the z-bar.
Old 01-22-2011, 06:12 PM
Manuel Azevedo
Manuel Azevedo's Avatar
body cradle
It's great when people come up and find a way to do something that most would say it won't work. Looks close in there but looks good!!!
Old 01-23-2011, 02:05 AM
LT1driver
LT1driver's Avatar
disconnect anything connected to body, get 4 buddies to provide support to front end(2) and other 2 to help you (1 to work lifting mechanism) and you and other to watch for things that might snag....go slow and watch front end as it is heavy and only glassed to main body and can and has broke on some good luck, again TAKE YOUR TIME
Old 01-23-2011, 09:46 AM
PUNISHER VETTE
....just moved here so I don't know 4 buddies and 2 others to help...
This will be by myself most likely or possibly one other.
Old 01-23-2011, 09:55 AM
PUNISHER VETTE
looks like bubba has been messing with my rear bumper.
This is what they call the valance right? well he glassed and painted over it so i'm having a hard time figuring out a way to get the thing off without damaging it too much.(even though it doesn't need to come off I don't think.
He also broke the fiberglass when he was messing with the bumper as both sides looked like this without me needing to loosen them...
But i'm gaining progress on the car...
I'm going to be gone all week for work but would still love any information that can help. type of engine hoist? Do i need the load leveler or will that take up too much of my height i'm limited with? should I buy the premade straps for the corvette lift and knot them to size or just use my tie down straps?
I can put a hole in the ceiling like the photos above but don't have the metal cradle to use and it's a rental house so i'd have to fix what i destroy...
Old 01-23-2011, 10:51 AM
wan2run
wan2run's Avatar
I used a Harbor Freight engine hoist in my garage with 8 foot ceilings. A leveler may help as the front strap is a little tricky. I didn't use one, but I was a little worried that the straps might slip. I used the same checklist everyone seems to use (meant for C2's). I obviously found some stuff that wasn't listed, but it was minimal. Just lift a little at a time and keep checking for things you may have missed.
You can do it by yourself, but I had 1 other buddy help.
Good luck!
Old 01-23-2011, 11:14 AM
PUNISHER VETTE
I'm trying to figure out what type of engine hoist to buy or look for used.
Seems like i'll need probably a 2ton even though a 1 ton would most likely do it.
But should I stay away from the folding types?
Is there a boom length or height I should be looking for?
Obviously if it doesn't lift high enough or extend far enough it's not going to work... I'm just trying to figure out what those numbers are and what I should buy...
Old 01-23-2011, 11:45 AM
Alan 71
Alan 71's Avatar
Hi PV,
You asked three questions yesterday and I answered two of them; did you see my post?
What you're seeing on the valance is what was often done when a car was changed from under-car exhaust to side-exhaust. If you look on the back side of the valance you should be able to see the 'patch' and then you'll know where to cut.
The broken fiberglass at the side bolt of rear bumper is pretty common (though yours is a unusually big hole) because until late 71 and into 72 there was no bracket for the bolt on the back side so the washer that was used was too big and broke the fiberglass around the hole if over tightened. A pretty easy repair.
Regards,
Alan
Old 01-23-2011, 12:02 PM
PUNISHER VETTE
Originally Posted by Alan 71
Hi PV,
Regards,
Alan
yes I saw your post this morning from yesterday and I think it'll help a lot.
I think I was confused about the cluck rod clip as a clip to me sounds like a wire clip. But if they're talking about the rod where it intersects to the Z bar I know that and can easily take that off.
i'm sourcing a hoist on craigslist this morning so i haven't been our to look for the tail light plug.
the hoist on Craigslist look like wan2run's. Most likely a harbor freight model. 2 ton folding type for $100 that isn't too far from me so i think that's what I'll get for now..
and the vanance is globed on the back with excess glass so there isn't much i can see with that...i'll just have to go slow and heat gun it while i peal it away
Old 01-23-2011, 12:07 PM
PUNISHER VETTE
http://philadelphia.craigslist.org/tls/2175414530.html
he said he leveler was a mistake and it's $100 for the hoist only...
think it'll do the trick?
Old 01-23-2011, 01:50 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
I placed a beam; two 2x6's nailed together, across the rafters in my garage. One end su8pported by the end wall, the other end I supported with a 4x4. Then I used a come-a-long to do the lifting. I also used a second come-a-long to lift the nose. I was able to do the lifting by myself from the attic area. The lift straps I bought from Vette Products of Michigan.
The one thing you need to check is the condition of the rocker channels. If I had looked closer I would not have used the hooks on them but would have wrapped the straps together under the body. My rockers were very rusty and they did bend a little from the lifting. Fortunately they held and the body did not drop.
Old 01-23-2011, 03:32 PM
PUNISHER VETTE
That's something I'll have to check. from the outside they look "okay" but knowing my car i'm guessing they're toast. I'll have to jack the body up a bit anyway to get the straps on so i can check out the rockers at that point.
I ended up getting the engine hoist off craigslist from a nice guy locally so hopefully it'll work out.
Old 01-23-2011, 06:52 PM
sly vette
sly vette's Avatar
The lift you have will work fine.
I did a complete body off resto on my '69 by myself with 8' ceilings in my garage.
If you take your time and have a plan you will find that there is not much you can't do yourself.
Good Luck and I will be looking forward to your progress.
To Body Lift Help
Old 01-24-2011, 03:46 AM
hunt4cleanair
hunt4cleanair's Avatar
Those wheel dolly's are a great idea...really contributes to a "one-man" job strategy. Like you, I've got that 8 (98") foot ceiling
Old 01-24-2011, 11:22 AM
wan2run
wan2run's Avatar
I am in the process of blasting the frame now. I'm sure my neighbors laugh at me everytime I drag the frame (by myself) to the back yard.
Old 01-24-2011, 11:33 AM
wcsinx
wcsinx's Avatar
Put out a call in the regional section. I bet you can wrangle some beer fueled help.
Quick Reply: Body Lift Help
