Frame Measurements?
Frame Measurements?
Does anybody have frame drawings for a 72 that would show measurements from the various measuring holes to suspension points, ball joint centers, ect? I am starting on a c-4 suspension conversion and that info would be helpful in locating the new suspension, getting the wheelbase where it needs to be, ect.
T.I.A.
Mike
T.I.A.
Mike
Received 2,878 Likes
Hi Mike,
I believe Russ' link is to a drawing from the GM CHASSIS SERVICE MANUAL.
There's also a drawing in the AIM that has some center line dimensions for a few of the suspension components.
I'd think you'll need more detail but these are the only 2 I'm aware of.
Regards,
Alan
Regards,
Alan
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Mike,
I struck out trying to find that same information when I was doing my frame. I ended up just making a separate jig to position the wheels in the correct (or desired) trackwidth, wheel base, and ride height, and then temporarily welding the frame to the suspension jig. After that, it was somewhat straightforward to start positioning the suspension arms in the desired angles and then welding in the appropriate attachment brackets. As I mentioned in our earlier conversation, be prepared to spend a significant amount of time cutting out areas of the frame that compete for space with the new suspension links. (Side note, remember that the C4 front spindles are not in line with the ball joints like earlier suspensions.)
Keep us updated!
Mike
Keep us updated!
Mike
Frame drawing
T.I.A.
Mike
T.I.A.
Mike
Here is a frame drawing that I believe is from a 74 or so. The only difference is the aft bumper rail. Yours curves up instead of down.
Ron [IMG][/IMG]
T.I.A.
Mike
T.I.A.
Mike
Received 1,470 Likes
Cruise-In II Veteran
I may be missing something here, but isn't there an aftermarket kit for adding C4 suspension pieces to the C3 frame?
I dont know of a kit to do that, you can buy frames or take your frame in and have it converted, both are buku bucks. I like tinkering and will enjoy the challenge of doing it anyway. Vetteguy, to answer your question, I didnt like the way the car drove with the latest of 50's engineering on the steering system and when I started seeing c4 conversion stuff showing up that looked like a good way to go. Keep in mind I started collecting stuff 7 years ago and I probably wouldnt go that route now what with all the c3 thats out now but I already made that decision so here I go. The c4 stuff is out of an 86 vette manual trans car.
