What's the difference between L48 and L82?
Old 01-20-2011, 02:29 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Originally Posted by jb78L-82
Hopefull, this information will put to rest that the L-82 is some knid of "dog" compared to the "high horsepower" SB engines of the late 60's/early 70's-it simply is not true.
I agree with everything you said above, but would like to add that a heads/cam change on an L-48 would also put it into the 400hp game.
Old 01-20-2011, 02:58 PM
Snoopysvet
Snoopysvet's Avatar
Originally Posted by 98MustGT
L-48s did not have smog pumps (Xcept CA and high altitude)
Found out just in 1978 L-48s did not have smog pumps (Xcept CA and high altitude
Old 01-20-2011, 03:25 PM
fauxrs
fauxrs's Avatar
Originally Posted by hunt4cleanair
Hey fauxrs:
Check out your webpage out of curiosity...you did some serious work on that 78. Looks great! What's your background...engineer? Nice display of data in tables. You must have a penchant for detail.
Engineer? Does Architect count?
Actually my car addiction comes form my Mom who raced cars in her youth. Attention to detail, I suppose probably depends on who you ask.
Old 01-20-2011, 06:52 PM
7t9l82
7t9l82's Avatar
Originally Posted by Evil Empire
"L-82 was a true performance engine" haha
forged crank forged pistons same as LT-1 was that not a performance engine? compared to the crap that was available at the time it was a great engine. N.H.R.A. factored it at over 300 horsepower. this engine is over 30 years old remember? is or an L-88? no, but then an L-88 was a race engine
Old 01-20-2011, 06:55 PM
jb78L-82
jb78L-82's Avatar
I agree as well but the L-48 has cast pistons, cast crank, and cast connecting rods which are forged on the L-82, good insurance in higher HP motors but I think the 8:2 compression ratio for the L-48 will make getting to the 400HP target more difficult than the 9:1 L-82 compression. The L-82 is just a much stouter engine as it came from the factory. The L-48 is a standard GM passsenger car 350!
Old 01-21-2011, 10:25 AM
Snoopysvet
Snoopysvet's Avatar
Sorry Fauxrs, just had to do it!
Old 06-29-2013, 09:16 PM
RCorvette Lover
1st Gear
RCorvette Lover's Avatar
Default quick question on L48 engine with manual 4 speed trans
I am looking at a 1977 Corvette....would be my first...VIN tells me it should be an L48 engine but it is 4 speed manual transmission. In my research I have not been able to find any reference to L48'swith manual transmission...and also I have seen references that only about 2000 Manuals were made in 1977...so my question is...did Corvette make the l48 engine with manual transmission in 1977 and this is just some rare one....OR is it possible the manual trans was added subsequently? Any assistance would be appreciated.
Old 06-29-2013, 09:34 PM
scottyp99
scottyp99's Avatar
Hi, Jack!
Scott
Old 06-29-2013, 10:03 PM
qwank
qwank's Avatar
L-48s were available with 4 speeds all the way to 1980, and in '81 the L-81 was also available with a 4 speed. the only thing that changed was 1980 L-82s were not available with 4 speeds.
Old 06-29-2013, 11:53 PM
Silver Vulture
Silver Vulture's Avatar
well if you check the casting numbers as far as block, heads, intake and exhaust they where the same, changes were in the reciprocating assembly ,crank rods, cam, pistons and ofcourse aluminum valve covers at least in 1974, check http://corvettec3.ca/casting.htm, hope this helps a bit
Old 06-30-2013, 12:03 AM
wcsinx
wcsinx's Avatar
It wasn't a good era for any engines no doubt.
The stock exhaust was a y-pipe to a single bead cat. You might as well be driving around with tennis ***** jammed up your tailpipes. Once you uncork them with headers, duals, x-pipe, and a decent intake, they wake up pretty damned well.
Old 06-30-2013, 12:41 AM
johnnyjaws
johnnyjaws's Avatar
l48 was still faster in the 1/4 mile ha ha
Quick Reply: What's the difference between L48 and L82?
