fuel overflow/71 454
OK...I still haven't figured out why I don't have fire to my plugs...but have new problem....while trying to crank new engine the fuel was overflowing out the top of the front tri-power carb....I took the float bowl off twice...the first time the float was stuck down,allowing the fuel to keep coming in....The second time I pulled the float bowl off I changed the float...still overflow......I guess I need a fuel pressure regulator...is that right?...Thanks.....As for the fire problem...I installed Pertronix 3...hot wire to coil is from the ign. tap on fuse box....have checked continuity from block to distributor and ground wire to points plate..everything good..do I need to get my fire to coil from somewhere else?...Thanks ..Malcolm
FLOAT NEEDLE STUCK. Float is only half of the system
Dr. Detroit
Received 3,891 Likes
Fact is the float system only has a few parts and is very simple.....overflowing can only be caused by one of five things:
1) Debris in the needle or damaged needle.
2) Dropped float...saturated nitrophyl or brass float that took on liquid.....
3) Incorrect float level setting
4) Fuel pressure way too high (7psi max on Holley)
5) Damaged/missing needle/seat O-rings seal to float bowl (This is VERY rare and will not "shoot" gas out of the vent, more like a trickle...)
95% of the time it is 1, 2, or 3......if you have a stock pump, 4 is out of the question.....if you see rubber bands on your needle assembly, number 5 is out too.
If the needle is clean and the float actually floats and is set proper....it has to seal. If it is debris or dirt in the needle, then it is coming from somewhere.....like a rubber fuel line inlet failing internally which breaks the inside rubber down to dust that goes right through the pump, through the pathetic screen filters on the bowl and clogs the needle....you clean it, put it back together and it works for a minute until more debris floats through and makes it leak again. So logic tells you......get a clean gas can....disconnect the inlet to the pump and run a long hose from the inlet to the gas can.....clean the needle and try again......
I cannot say enough about float setting either and is one of the mos misunderstood and plain overlooked aspects of any carb. The Holley has a sight plug in it and you remove it while the engine is running.....start with a float setting that is way too low and dial it up until you see a trickle come out......wrap the intake with a damp rag for safety.
Make sure the float floats! Brass is easy....shake it...if it has fuel in it you will feel it....the black Nitrophyl can be put in a bowl of fuel to check......
Check these things and it will work......because it has to.
Jebby
Dr. Detroit
Jebby
My front carb on my 68 tripower was overflowing fuel. Took in apart three times until I discovered the float hinge was slightly bent. It would move freely when the bowl was off the carb but when installed it would hand up on the metering plate causing the flooding.
I have a feeling that when I put the float bowl back on that the float is wedged against carb. base....have new neoprene float ordered and new spring to help take some weight off the float...neoprene float is not as thick from front to back as brass float..will allow space between float and carb. base..maybe solve the problem before I do fuel regulator
pltmgr (10-28-2021)
Been following this thread with interest trying to learn. You have had the unit back to Toms and it bench test good. However never mentioned if you used your distributor to check the unit. Are you sure your distributor is turning your hp pump? I agree with the need to verify timing, but the problem is no fuel flow.
Drive em safe
Leo
Drive em safe
Leo
