Flexplate weight
Thats the part I don't get, when you buy a new flexplate, how do they know where to put the weight? Would they not need to spin my motor to figure that out, or is the weight just to balance the plate itself? If the latter is true, then why is the 427 plate not balanced?
The imbalance weight, when welded to the flexplate during manufacture, is located by reference to the seventh hole.
On an externally balanced motor the flex plate or flywheel on one end and the damper on the other are either drilled or weight added to balance the motor as a complete unit.
If you replace any one of these components you will need to have it made the same (weight balance) as the part being removed.
Internally balanced motor use neutral weight dampers and flex plates or flywheels
AvRog, I would have a quality shop help you in making something close to what the original was.
I've put several standard balance flex-plates on stock 454s and they did fine. I'm sure a better balance could be achieved by an engine shop but most don't want to pay what it would cost.
