Reverse Lights
Old 01-17-2011, 05:39 PM
desertdogs50
Cruising
desertdogs50's Avatar
Default Reverse Lights
My reverse lights are not working, bulbs have been replaced, fuse checked, other than replacing the actual switch what could be wrong, all ideas welcome. Thanks
Old 01-17-2011, 05:57 PM
LB66383
LB66383's Avatar
It could be the switch, it could be a bad ground, it could be a poor connection somewhere. Are you getting voltage to the bulbs when it's in reverse?
Old 01-17-2011, 06:30 PM
desertdogs50
Cruising
Default Reverse lights
I'll Check and try to run it down with the volt meter
Old 01-17-2011, 06:31 PM
myk7
myk7's Avatar
Automatic or 4 speed? Tried running through all gears?
Old 01-19-2011, 09:41 PM
Go Vette
Go Vette's Avatar
My car failed inspection last year. I didn't even know the lights weren't working. I took it home and looked underneath the car. The little rod that connects the switch at the tranny had come loose. A 10 cent retainer from the hardware store fixed it. I'm sure the geniuses at the shop would've have charged at least a hundred clams to fix it. Hope yours is as easy.
To Reverse Lights
Quick Reply: Reverse Lights
