what's this green fluid on the intake manifold? pics
I don't think the anitfreeze tastes sweet anymore. There were so many instances of people drinking it (unknowingly) that manufacturers had to change the recipe so it wouldn't be sweet. Good news for the dogs too.
I tasted the coolant in the recovery tank and it's sweet. the one on the intake manifold doesn't have the same taste.
i did it some days ago. ok i won't do that anymore.
so what to do now? detach the intake manifold and put new gasket? hate to do that...
ah , before retorque the leak was much more and i found just a tad of that green stuff on a couple of spark plug. just a bit .
the engine runs great anyway and no white smoke, no oil consumption...
advises welcome
p.s. the engine has been made by a reputable engine builder that makes tons of BB for race. It's difficult to think to any mistake from his side considering how meticolous he has been in the whole engine build
advises welcome
I have checked right now the engine and surprise... everything is dry and no sign at all of that leak. i took the pics posted yesterday after a ride then i shut the hood close.
so what is it? the oils doesn't evaporate but i know that also the coolant doesn't evaporate easily and can stay long time there. am i wrong ? my coolant 50/50 water and alu coolant
i have checked also spark plugs 2 and 4 and they are fine
Received 1,895 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Any chance you used the copper looking never seize on the intake bolts? I know when the jar sits around for awhile it separates out and has to be stirred up. The liquid part of it looks very similar to that color.
JIM
JIM
do you think that permatex ultra-copper rtv was used to help seal the manifold. I know its been recommended to seal the bridges in front and rear of the block and not use the rubber/cork seals. my $.02s.
mike
mike
68 70 vette is correct, unless you are p----- off at your liver, I'd not taste that stuff. Dogs will drink that stuff and it crystalizes their liver. Heat it on some steel and it will have a sweat odor if anti freeze. Your liver will like you again.
Hi Aldo! I check in once in a while. Could be some type of assembly lube or sealer. I will check with Tim and see what he uses. Glad to hear it is running strong! Sometimes after repeated heat cool cycles you will need to retorque some things, especially aluminum to aluminum surfaces. Looks like you did that and seepage stopped. Good news.
yes check with Tim ( the engine builder) , possibly same thing on other engines he made.
few miles on my engine but many heat cycles. the intake bolts were at slightly less than 30 ft-lb before retorque. torqued again at 35
should i drain the oil from the pan and check for coolant?
thanks everybody for the "brainstorming"
Hi Kevin
#33
I'd say the green substance is some type of "anti-seize" f/ bolt threads. (...and write to the mfg. to request that they flavor their product w/ something tasty, ie; Jack Daniels, Taquila, or how about Blue Bell ice cream flavors???)
#35
the engine builder says to also check the head's bolts tq that could be relaxed due to aluminum expansion. i'll do it.
which is the head bolts tq? my book says 65 ft-lb for short and 75 ft-lb for long bolts
note: this green fluid evaporates fast with engine heat. still leakin a bit after intake retorque. no many chances to take the car out for a ride because bad weather
