What is the kick down passing gear switch called?
Old 04-08-2002, 06:43 AM
69er
69er's Avatar
Default What is the kick down passing gear switch called?
Don't have a passing gear.I figure maybe the switch is bad.
Don't know what the switch is actually called on a TH400 unless it's just called the kickdown switch.
I only looked in one catalog so far and can't find it.
Old 04-08-2002, 08:30 AM
ddecart
ddecart's Avatar
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: What is the kick down passing gear switch called? (69er)
I always thought it was just the kickdown. Can't recall or even make up a different name for it.
Dave
Old 04-08-2002, 09:09 AM
TravMsns
TravMsns's Avatar
Default Re: What is the kick down passing gear switch called? (ddecart)
throttle kickdown
Old 04-08-2002, 11:46 AM
DaBo
DaBo's Avatar
Default Re: What is the kick down passing gear switch called? (TravMsns)
kickdown switch. :yesnod:
Old 04-08-2002, 01:35 PM
Tom73
Tom73's Avatar
A Detent Switch maybe? At least that is what it is on the '73.
tom...
Old 04-08-2002, 02:02 PM
Cookwithvette
Cookwithvette's Avatar
Default Re: What is the kick down passing gear switch called? (Tom73)
Tom got it Detent Switch. :yesnod:
Old 04-08-2002, 04:35 PM
69er
69er's Avatar
Default Re: What is the kick down passing gear switch called? (Cookwithvette)
Thanks for the replies guys.
It is a Detent Switch.
I see one in rik's but for 70-77.
It seems a '68-'69 isn't listed.
Any ideas?
Old 04-08-2002, 04:43 PM
Alwyn678
Alwyn678's Avatar
Are u sure it is hooked up??? when I put in my new tourque converter mine was actually unhooked
Old 04-08-2002, 05:12 PM
69er
69er's Avatar
Default Re: What is the kick down passing gear switch called? (Alwyn678)
Good point.
I didn't install my TC. :cheers:
Old 04-08-2002, 05:16 PM
ZD75blue
ZD75blue's Avatar
The moment that a small block feels like a bigblock... :(
Old 04-08-2002, 05:42 PM
69er
69er's Avatar
Default Re: What is the kick down passing gear switch called? (ZD75blue)
Sort of :lol:
Thinking back never had a problem after performance trans rebuild and 2400TC.
This problem started after I went from a Holley Avenger carb to my Lars rebuilt qjet which runs great.
Linkage?
[Modified by 69er, 4:02 PM 4/8/2002]
Old 04-08-2002, 07:06 PM
Matt Gruber
Matt Gruber's Avatar
i call it a lever switch. Got 6 out of an old VCR.
radioshack sell them for $1.99
Put another one on the console for "paddle" shiftng.
Old 04-08-2002, 09:55 PM
69er
69er's Avatar
Default Re: What is the kick down passing gear switch called? (drives61)
Interesting!
To What is the kick down passing gear switch called?
Quick Reply: What is the kick down passing gear switch called?
