Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-17-2010, 01:09 PM   #1
TheycallmeDave
CF Senior Member
Default High Crankcase pressure after complete rebuild ; what went wrong ???
I had a buildup done on the 1970 BB Coupe a couple years back with an Edelbrock Power Package and Total Seal Ringset.... and while the power increase is phenominal, the rear main seal started leaking from almost day one , even with a correctly functioning PCV . After trying different rear main seals, the problem continued to occur . He assures me that the motor/trans are properly aligned, and there is no vibration whatsoever. The block was sent out to be bored .060" over , honed, and cleaned . The Mechanic who did the rebuild has done many in the past and had several Corvettes in the family .
The performance is MUCH to my delight and estimated at 550 gross h.p. (up from 390 stock) and im somewhat reluctant to have the motor teared into again .
. Is it likely the rings didnt seat properly / or were incorrectly gapped ?
Thanks for any insight.
TheycallmeDave is offline   Reply With Quote
Old 12-17-2010, 01:20 PM   #2
L88Plus
CF Senior Member
Have you done leakdown or compression tests?
L88Plus is offline   Reply With Quote
Old 12-17-2010, 01:28 PM   #3
gkull
CF Senior Member
gkull's Avatar
do a leak down test. pull off the PVC while the motor is running and rev it up. See how much blowby you actually have. I can't imagine a refreshed motor building so much internal pressure that it pushes the gaskets out.
gkull is offline   Reply With Quote
Old 12-17-2010, 01:31 PM   #4
mysixtynine
CF Senior Member
mysixtynine's Avatar
How many breathers do you have on the engine? Most high perf. engines will need one breather per valve cover instead of a pcv valve.
Leak down and compression checks would be another good idea.
I have heard of stock 5.0 ford engines n crown vic's blowing out the rear main because the pcv's were getting clogged.
mysixtynine is offline   Reply With Quote
Old 12-17-2010, 01:52 PM   #5
ajrothm
CF Senior Member
ajrothm's Avatar
I'm voting on it being a main cap/crank issue. I couldn't imagine crank case pressure pushing a rear main seal unless there was no breathers at all.
I run a pcv and a small chrome breather ony 496" with no issues at all....and I race it often.
ajrothm is offline   Reply With Quote
Old 12-17-2010, 02:33 PM   #6
midyearvette
CF Senior Member
Support Corvetteforum!
midyearvette's Avatar
throw away your pvc set up and go with breathers on the valve covers to the atmosphere....this is a common occurance with total seal rings...just call them and they will explain why....also it should have been with the instructions that came wit the rings......
midyearvette is offline   Reply With Quote
Old 12-17-2010, 04:34 PM   #7
TheycallmeDave
CF Senior Member
Quote:
Ive tried a breather on each valve cover and i still get rear main seal leakage ; the oil ends up on the gearbox. Im going to try breathers plumbed to the Header Collectors for a cheap exhaust purge system. I may get a leakdown test done as well.
Thanks to all.
Old 12-17-2010, 06:38 PM   #8
gkull
CF Senior Member
gkull's Avatar
Thanks to all.
If you have twin breathers you do not have any crank case pressure.
Also header breathers only really work in a system that has no back pressure like uncapped headers. It just uses venturi effect to draw a vacuum. That doesn't happen on a mufflered full length system
Old 12-17-2010, 06:48 PM   #9
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Are you using the Total Seal rings again, with a gapless top ring or gapless second ring ?
MotorHead is offline   Reply With Quote
Old 12-17-2010, 06:52 PM   #10
7t9l82
CF Senior Member
7t9l82's Avatar
i used the check valve off a brake booster in place of the PCv valve kind of a cheap vac u pan
7t9l82 is offline   Reply With Quote
Old 12-18-2010, 12:08 AM   #11
73, Dark Blue 454
CF Senior Member
It's hard to imagine you'd have enough blow-by on a fresh engine to blow out the seals and/or gaskets. A couple of questions:
1) Have you used the dye to diagnose the origin of the oil leak? "Dye don't lie". You may have a leak at the rear of the intake or rear of the valve covers that can look an oil pan gasket leak or real main seal.
2) What engine and which PCV valve are you running and to where does the hose go (vacuum source)?
2a) How does fresh air enter the crankcase? A breather on the other valve cover?
73, Dark Blue 454 is offline   Reply With Quote
Old 12-18-2010, 09:33 AM   #12
TheycallmeDave
CF Senior Member
1. Havent tried Dye. Its definetely the rms as its been replaced twice now . (Didnt have the problem before the engine build) . No leakage from the valve covers at all.
2. 454 bored to 468 cid. Factory block. Dont know the brand of the PCV but it sucks good and vaccuum source is a big port at the bottom of the carb (Demon 800 cfm) .
2.a. Yes, breather on the other valve cover.
Im pretty sure its a TotalSeal gapless second ring.
Old 12-18-2010, 09:44 AM   #13
Vette5.5
CF Senior Member
You didn't mention much about the rear main seal. If the crank was originally set up for a rope seal it will have some small groove's in it and will tear up a neoprene seal unless they're machined off.
Vette5.5 is offline   Reply With Quote
Old 12-18-2010, 09:52 AM   #14
noonie
CF Senior Member
noonie's Avatar
I've seen several new engines over the years with enough crankcase pressure to blow the dipstick out of the tube and push oil at almost every spot.
Good pcv was the cure, but these were pretty stock sbc's.
You can connect a vacuum gauge to valve cover opposite the pcv and test for pressure or vacuum, should be negative except at WOT.
noonie is offline   Reply With Quote
Old 12-18-2010, 11:11 AM   #15
roscobbc
CF Senior Member
roscobbc's Avatar
Had similar issues with my (then) freshly built 489 - it was using significant amounts of oil - using atmospheric vents from each valve cover - didn't seem to have too much crankcase pressure - then found one of the culprits (dipstick tube not sealed into block - oil mist being pumped-out under car and burning-off exhaust. Cured that, then tried to cure constant oil weeping from valve cover breathers - so went to PCV valve set-up which helps drivers side oil weeping, but not passenger side - swapped PCV side to side & same issue on opposite side. Did some thinking and came to conclusion that as I am using 'tall' Brodix 'non-baffled' valve covers, with oil pressure that goes of the gauge there is a lot of oil being flung around inside the valve cover and I reckon the 'squirter' for one of the rockers ejects oil right underneath the valve cover vent. I intend riveting/welding some baffles within the covers over the vents and see if that helps reduce the problem.
roscobbc is offline   Reply With Quote
Reload this Page High Crankcase pressure after complete rebuild ; what went wrong ???
Tags
468, 88, blow, buy, case, crank, crankcase, dipstick, engine, excessive, high, motor, pressure, rear, sbc, seal, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
