making C3's run 0-60 in less than 5 sec's?
Ok all you C3 owners... I'd love for my 77 4spd to run 0-60 in the 4.5 - 5 sec range My C5 don't have any issues accomplishing that task at all.. But my poor little 77 would be lucky to get 60 in 10 seconds! LOL Just got this car, i've stripped the interiors out and im going to go get her painted then replace the interior then i want her to have some power... just not sure what i want to do... It's a matching number car and Im not sure i want to take the engine out and replace it... it's only got 80k original miles on her.
BLUE1972 (01-15-2021)
St. Jude Donor '12
I put true duals exhaust on mine, then recurved the Distr. like "Lars" stated in his article. Then put on an extream air lid so the carb can suck more air from the top. I also opened up the hood cowl to allow air to be sucked in that way also. No smog control, no EGR valve, and a BB rad. which runs at 180 degrees all day long. My 77 L-48 auto spins the "dickens" of the rear tires at any light. Talk about fish tails. My son loves it. Can't deny It puts a smile on my face too! And the tires have great tread.
Pic of the air cleaner lid. I'm expecting a L-82 dual snorkel air cleaner to come, I'll be placing that on next with a spacer.
I could get 0-60 times of just a hair over 6 seconds flat with what was basically a stock L-48, with 1 5/8" headers, dual 2.5" exhaust. Car had 3.55:1 gears and a 700R4. Make sure your car is in good tune, I don't think even an LG4 should take that long to get to 60.
Les is on the money - tires are very important. Even the highest power cars won't get <5 if they can't launch for beans.
Big Block Dave (01-15-2021)
My totally stock 78 L-82 4 speed (3.70) ran 0-60 when new of 6.5 sec (79 L-82 Auto did 6.6). I have 2.5 true duals, 1.58 in shorty headers, roller rockers, recurved distributor. Holley 4175 650 spreadbore (just rebuilt it Friday-easy), zero pollution control (No cat, AIR pump and hardware (AIR tubes deep in the head creating exhaust turbulence and restriction), EGR valve, heat riser valve, etc), and an engine operating temperature of 160 (not 225+ from GM when the car was new) and it will easily get into the high 5's.
On the other hand, stuffing a 500+ horsepower engine into a C3 does not mean it will run 0-60 (3.6 sec) with a C6 Z06-not even close! The horsepower equation is easy. Putting the power down through a C3 chassis including a tire that can handle the power without smoking the tires is completely another matter all together.
Well, your car has 80K miles...and 33 years on it. You can always increase horsepower/torque to make the car capable of the acceleration rate you require. But, can the drivetrain of the car handle that level of power...and do it safely? You will need to do a lot of repair upgrading to several of the major systems in the car to allow it to achieve that kind of performance; especially if you want to do that more than once!
St. Jude Donor '12
You need to make sure your drive shafts,transmission,motor mounts, and a few other key parts are all in A1 shape. Otherwise you will be chasing every broken part all the time.
The following 2 users liked this post by Nobody.:
Rescue Rogers (01-23-2021),
scottjamison (02-19-2021)
a 454 LS-7 will get you 1.6 60' times,.... never looked at the speedo and dont know how fast that turns out to be. But it will put you right up at the front of the pack........
Ther's no doubt that a lot of hp will do it for you, but I'm surprised that no one mentioned a 5 or 6 speed trans. I have the Richmond 6 speed. Gears 2-5 are very close to those in the Muncie. First gear is 3.27 and sixth gear is a 0.75 overdrive. The acceleration in first is a lot of fun. The tranny alone might not get you 0-60 in sub-5s, but it will definitely get you closer and make your driving a lot more fun.
Do the math. 3.27 first gear x 3.36 rear = 10.99 final drive ratio. This is better than running and M-21 with 2.20 first gear ratio and 4.56 rear (10.03 final drive). As an added bonus, you'll be revving at 2000-2500 on the highway in sixth gear.
My main point is that the high final drive ratio will help your acceleration.
