Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-09-2010, 11:59 AM   #1
DRC
CF Senior Member
DRC's Avatar
Default Anyone Jet-Hot coat BB exh. manifolds?
I know heat is an issue with some of the BB's, so wondered if anyone has had their stock BB exh. manifolds Jet-Hot coated in the flat cast iron gray color. Thinking this keeps the stock look, may cut down on heat, and help exhaust flow.
DRC is offline   Reply With Quote
Old 12-09-2010, 12:49 PM   #2
Corey_68
CF Senior Member
Corey_68's Avatar
Quote:
I have mine ceramic coated black, cannot comment on the heat difference as I have yet to drive the car for an extended period and in the Summer.
Corey_68 is offline   Reply With Quote
Old 12-09-2010, 01:12 PM   #3
mark@BBExhaust
Premium Supporting Vendor
mark@BBExhaust's Avatar
Not sure that you will really see any increase in exhaust flow however coating the manifolds will definitely help with under hood temps and keep them looking good.
__________________
Mark Fowler
Billy Boat Performance Exhaust
888-228-7435 Ext.18
mark@bbexhaust.com
mark@BBExhaust is offline   Reply With Quote
Old 12-09-2010, 01:24 PM   #4
Vette5.5
CF Senior Member
I have Jet Hot coated longtubes on one of my car's and still look like new. Jet Hot does warn about running very lean carb A/F ratio's that can cause exhaust temperature's to soar though. Don't think BB's run any hotter than most engine's, just create larger quantity's of heat. Maybe scan your manifold's with a IR thermal gun and contact Jet Hot. Coating the manifold's may help underhood temperature's a bit, but you still have the raw steel exhaust pipe's running up to them.
Vette5.5 is offline   Reply With Quote
Old 12-09-2010, 10:00 PM   #5
1969RAY
CF Senior Member
1969RAY's Avatar
As I rebuilt my car, I was looking for a way to coat the original manifolds and came upon something called "aluminizing". Cost me $100.00 bucks total for both sides. That was five years ago and they look just like they did when I put them on. They're white with a mat finish. I've spilled a little oil, etc. on them and it burns off with no affect on the finish. Its another option. Had it done at a metal fabrication, sand blasting shop.
1969RAY is offline   Reply With Quote
Reload this Page Anyone Jet-Hot coat BB exh. manifolds?
Tags
cast, coating, exhaust, hot, iron, jet, manifolds
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
