Drivers side window adjustment
So tonight a friend came over from the forum (thank you Ben!) to help me do some work on my '73. Last week I removed the drivers side window and replaced all the rollers and tonight we put the window and regulator back in the car.
Adjusting these windows is a nightmare!!!
So after we put the window in and swear that we've tightened every nut and bolt, I can still grab the window and move it back and forth and up and down...I'd say about and inch or so each way.
What could cause this...especially since we replaced all of the rollers? Anyone have any suggestions on what to do?
Appreciate it!
Appreciate it!
Back and forth movement: Did you install the anti rattle cushions? Without that cushions you can move the window easily back and forth.
Up and down should not be possible to move easily and that much (a little play is possible since you can "twist" the horizonzal guide a bit or move the rollers in the horizontal guide by moving the window.
The vertical guides are fastened properly (two bolts at the top, one at the bottom)?
Any pics?
Any pics?
Yes we have the anti rattle cushions installed and the vertical guides as well. The back and forth movement I'm referring to is to the front of the vehicle and to the rear of the vehicle. I can also 'tilt' the window by grabbing it and moving one way or another. Again, about an inch or so, making it impossible to get adjusted! Thoughts?
Driver window
I will add my 2 cents worth, although you have replaced every thing, I dint here you say anything abought the window regulator, If it is the original one it is worn just like all the other parts you have replaced the rivets ware in the holes and this will give you slop in every direction. You might want to check it. How do I know. Just replaced everything in my driver window, except the regulator, window loose as a goose, replaced regulator, Problem solved. Good Luck.
Well that would really suck but I bet you are 100% right. These things are a PITA!!! I mean seriously....was this the best engineering could do back then? LOL. Those windows and rollers are not easy to get in and out.
1 Post
because their engineers didnt actually work on the cars. when i was training as a BMW cycle tech, i found out that you have to have been a mechanic for many years before you could be hired on as an engineer. that policy shows too. theyre the easiest motorcycle to work on of the dozen or so brands i've worked on.
If you have the AIM, on page UPC 1, K2, there is a roller bolted to the forward end of the glass. This roller goes into the vertical guide, forward end of the door. This roller and guide should limit the front-rear travel.
Is this roller loose on the glass? Did you get the roller into the channel? Is the channel (guide) securely fastened to the door, top and bottom?
There are four bolts on the top of this guide, the inner bolts when loose allow the guide to shift forward or backward. This should be the limit of possible travel, only when the bolts are loose.
The anti rattle cushion will tend to stiffen the window travel in and out, toward the console and away from.
1 Post
Cruise-In VIII Veteran
look at the picture above. toward the center there are two screws marked "C". they control the window tilt. make sure they are fastened and make sure the roller for the short channel they control is actually in the channel.
Received 1,470 Likes
Cruise-In II Veteran
FriscoSteve, The assembly instruction manual (AIM) has the best written instructions for door glass adjustment. Purchase the AIM and follow the steps in the order they are listed. That's how the door glasses were set on the assembly line.
