**New Offset Rear Sway Bar - 63-79**
Premium Supporting Vendor
1963-79 Corvette Rear Off Set Anti-Sway Bar
•Fits Off Set Trailing Arms Only
•Provides Wheel/Tire Clearence for Deep Back Spaced Wheels
•Improves Handling
•American Made
Van Steel continues to lead the way with this precise fitting “Off Set” rear anti-sway bar kit for the 63-79 Corvette. This kit restores handling lost to the lack of a rear sway bar when using a deep back spaced wheel. The new fitment is now with in the confines of the chassis’s frame and is designed to attach only to an Off Set Trailing Arm. The bar is designed to provide torsional roll resistance between the 5/8” and ¾: OE style bar.
Included in this kit is a black powder coated chromoly bar, polyurethane bushings, powder coated brackets, end links and needed hardware. Special drill bit and allen wrench also included. Average mechanical ability and tools are need to perform the installation. Van Steel warrants this bar against defects for as long as you own the car
Link to Site
http://www.vansteel.com/index.cfm?fu...p=1701&ID=3223
Flickr Pics
http://www.flickr.com/photos/corvett...7625383389951/
Note: Instructions will be available shorty. We can help walk you through the install if you choose to buy the bar before the instructions are completed
•Improves Handling
•American Made
Link to Site
Flickr Pics
Very nice. it is good to see a vendor updating / making parts etc that we need. Keep up the good work
