Quick Question....Spark plug gap????
Old 04-05-2002, 08:40 PM
QuickVet
QuickVet's Avatar
Default Quick Question....Spark plug gap????
i am starting to change my plugs right now and was wondering what gap most of you are running? I have the ZZ4 heads, if that helps.
thanks,
AARON
Old 04-05-2002, 08:48 PM
PRNDL
PRNDL's Avatar
Default Re: Quick Question....Spark plug gap???? (QuickVet)
.035
What is your iginition? I believe some of the electronic ignitions with a highpowered coil (Specifically thinking of Pertronix) allow you to use a wider gap if you want. MJ
Old 04-05-2002, 08:52 PM
dgruenke
dgruenke's Avatar
I don't know if the heads make a difference, but most cars run about .044. :chevy
Old 04-05-2002, 09:25 PM
QuickVet
QuickVet's Avatar
Default Re: Quick Question....Spark plug gap???? (dgruenke)
ok thanks for your help. I put them in the car at 40 because i wasnt sure. we see how it runs tomorrow. thanks for your help.
if im way off let me know. I can still change em again ;)
the ignition is an MSD HEI. thanks
Old 04-05-2002, 09:28 PM
Paul 75 L82
Paul 75 L82's Avatar
With the MSD HEI you could probally go as wide as 60.
Old 04-05-2002, 09:53 PM
QuickVet
QuickVet's Avatar
Default Re: Quick Question....Spark plug gap???? (Paul 75 L82)
anyone know the stock gap for the zz4?
Old 04-05-2002, 10:19 PM
PatsLs1vette
PatsLs1vette's Avatar
i thought i saw it was 35 some where not sure ill look again
Spark Plugs:
MR43LTS Gap .045, AC FR5LS Gap .035, Rapid Fire #5 Gap .045. http://www.sallee-chevrolet.com/Chev...ckV8s/355.html
[Modified by pats406nitrovette, 9:20 PM 4/5/2002]
Old 04-05-2002, 10:22 PM
mountainmotor
mountainmotor's Avatar
The same as any small or large block Chevy that uses a HEI Distributor so the same as your L82 was when stock
With a hot ignition system the rule of thumb is wider gap for town use/mild performance.For racing in high compression engines,narrow the gap to prevent misfire and or blown out spark at high RPM.
A Vertex Mag works best at.022 with a cold plug
Old 04-05-2002, 10:24 PM
QuickVet
QuickVet's Avatar
Default Re: Quick Question....Spark plug gap???? (pats406nitrovette)
guess i will be safe at 40. but then i will change em for more gap later.
Old 04-05-2002, 10:54 PM
4_inch_Bore
4_inch_Bore's Avatar
according to Chilton's...
.035 all 1963-1974
.060 all 1975-1976
.045 all 1977-1984
Old 04-05-2002, 10:59 PM
QuickVet
QuickVet's Avatar
Default Re: Quick Question....Spark plug gap???? (4_inch_Bore)
.035 all 1963-1974
.060 all 1975-1976
.045 all 1977-1984
that is if your not modified correct? when you have new heads you gotta go by the plug that fits that head, correct?
Old 04-05-2002, 11:08 PM
mountainmotor
Quote:
"060 all 1975-1976"
That has since been changed back to .045
Quote"
"that is if your not modified correct? when you have new heads you gotta go by the plug that fits that head, correct"
Correct !
[Modified by mountainmotor, 9:09 PM 4/5/2002]
Old 04-06-2002, 11:04 AM
fontking1a
fontking1a's Avatar
I've found that widening the gap in spark plugs seems to make the car run better with this crummy fuel that we must use. My '69 427/435 calls for a .035" gap but I run mine at .045". At .035" the car wants to run a bit rich and just by opening the gap in the plugs, it runs like a champ. I've been doing this for almost 20 years and so far, no ill effects.
Old 04-06-2002, 11:38 AM
73Ken73
73Ken73's Avatar
Default Re: Quick Question....Spark plug gap???? (fontking1a)
I have been told by engine builders, racers, and performance part store owners that a .035 gap is good no matter what ignition you have or what mods have been done.
Old 04-06-2002, 09:15 PM
Vetterodder
Vetterodder's Avatar
The main consideration when deciding the gap is the ignition being used, the compression ratio, and the anticipated rpm. Most electronic ignitions allow for a wider gap, which is usually benefitial at lower rpm but too much gap can be a problem at high rpm. The instructions for my MSD box recommended gaps from .040 - .060 depending on cr, higher cr's using less gap. If you don't want to experiment, set `em at .045 and you should be ok.
To Quick Question....Spark plug gap????
Quick Reply: Quick Question....Spark plug gap????
