Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-25-2010, 08:13 AM   #1
corvette7576
Junior Member
corvette7576's Avatar
Default 5/6 Speed Transmission Swap
Hello Everyone,
I recently dropped a 383 stroker into my 75 and would like to replace my Borg Warner t-10, 4 speed with either a 5 or 6 speed. Does anyone know of a transmission that will bolt right up to my existing bell housing with out any modifications?
Thank you
corvette7576 is offline   Reply With Quote
Old 11-25-2010, 09:13 AM   #2
Garys 68
CF Senior Member
Richmond 5 speed (1.00 5th, or OD 5th) or 6 speed (OD 6th gear). Uses factory bell housing, clutch, z bar, shifter location, speedo cable, driveshaft. Only mod required is to the trans mount. That cost me about $20 extra.
Garys 68 is online now   Reply With Quote
Old 11-25-2010, 09:22 AM   #3
Gordonm
CF Senior Member
Gordonm's Avatar
The problem is with the welded in cross members on the 4 speed cars. The Tremec 5 speeds can be done with leaving the member in but it is real tight. I have done a bunch on coversions from auto to 5 speed and 4 to 5 speeds. I always make the cross member removeable. It makes it way easier and for any future works it makes removal a breeze. I can drop the 5 speeds out in about 1/2 hour with removeable members. I had a Tremec in mine and now have a T56 6 speed. That requires a lot more work. The Tremec kits are a bolt in but are somewhat costly. There have been a lot of different 5 speeds put in C3 cars. Some bolt in some require more work. I have a car in my garage right now that I just put in a Tremec 5 speed from a Borg Warner 4 speed. Only takes a few hours now that I have done a bunch of these. Do your homework and see what you need for strength in the trans and do you want an overdrive transmission.
Gordonm is offline   Reply With Quote
Old 11-25-2010, 10:11 AM   #4
John 65
CF Senior Member
John 65's Avatar
World Class T-5 for me. Lots of fun for not a lot of coin.
http://forums.corvetteforum.com/c3-g...-finished.html
Good luck with your project !
John 65 is online now   Reply With Quote
Old 11-25-2010, 09:44 PM   #5
FlyViper
CF Senior Member
FlyViper's Avatar
Gordon, did you just cut the crossmember out and weld plates on the ends to just bolt together when installed in the frame? Does the structural integrity of the frame change at all? I want to do one of these installs in the future, but that crossmember is such a PITA.
FlyViper is offline   Reply With Quote
Old 11-26-2010, 07:34 AM   #6
Gordonm
CF Senior Member
Gordonm's Avatar
I cut mine and welded on some brackets. Mine bolts from front to back. Some of the other installs have welded plates and bolt in side to side. I have not noticed and frame structure probelms my way. I just did another car the same way and it works out OK. Not as pretty as the other brackets but it works.
Old 11-26-2010, 08:45 AM   #7
Garys 68
CF Senior Member
If I was going to do it again, I would probably cut the original crossmember out and put in an aftermarket bolt in. I dont need the exhaust clearance since I'm running sidepipes.
http://www.speedwaymotors.com/Straig...ount,3279.html
Old 11-26-2010, 06:28 PM   #8
72LS1Vette
CF Senior Member
72LS1Vette's Avatar
Quote:
I'm guessing that a manual trans crossmember that has been cut and bolted together is at least as strong as an auto trans crossmember, probably stronger. The auto trans crossmember is held on by one main bolt and two smaller screws per side.
Rick B.
__________________
72 Ontario Orange Coupe. 2001 LS1 - LS6 block & Intake, Thunder Racing Cam, Ported heads and Throttle Body, Meziere electric water pump, Hooker Shorty Headers, 2001 T56 6-speed trans, VB&P Street & Slalom suspension, Magnaflow exhaust, DeWitt's radiator, SPAL fan, C5 power seats. Future mods: HydoBoost, Borgeson steering box, floor mats.
72LS1Vette is offline   Reply With Quote
Old 11-26-2010, 08:50 PM   #9
FlyViper
CF Senior Member
FlyViper's Avatar
Wow, didn't know that. Well, that does make me feel better. I don't have any experience with welding, so I'll have to take it to a frame shop or something. Any guess on what it would costs to have this done?
Old 11-26-2010, 09:09 PM   #10
Gordonm
CF Senior Member
Gordonm's Avatar
No need to take it anywhere. Find someone local. There are plenty of guys with welders on their trucks that will do it. I have 2 guys that I use and both are very reasonable. It would take them maybe a 1/2 hour to weld on the brackets. It really is not a big weld job to do.
Old 11-26-2010, 11:20 PM   #11
Darrell's 68
CF Senior Member
Darrell's 68's Avatar
In the process of putting in a T45Rs 5 speed overdrive right now. I have a 4 speed car with a welded in crossmember and I did not cut it out and weld in brackets. The only mod I had to make was to cut a hole in a slightly different place in the trans tunnel for the shifter but it looks stock with the shifter console back in place.
I was pulling the engine anyway to freshen it up so it was not a big deal. I will say that if I need to pull the trans or service the clutch assembly at a later date, I will cut out the crossmember instead of pulling the motor again.
Darrell's 68 is offline   Reply With Quote
Old 11-26-2010, 11:24 PM   #12
FlyViper
CF Senior Member
FlyViper's Avatar
I figure if I'm going to put a new tranny in, I might as well cut the crossmember then, considering future work as you mentioned. I guess I'm most afraid of actually cutting my crossmember, never really done anything like that. There's two place I'd like to get patched on my frame anyways, so since I need to take it to a frame shop anyways, might as well have them do it.
Old 11-26-2010, 11:39 PM   #13
Darrell's 68
CF Senior Member
If you're going to a good frame shop, I am sure they can do a great job fixing your frame and modifying it so it could be returned to a factory look at a later time. That's probably what I should have done, just could not bring myself to cut it out right now. Would have made my swap a lot easier!
Old 11-26-2010, 11:48 PM   #14
FlyViper
CF Senior Member
FlyViper's Avatar
Yep, I've already pulled the engine/tranny, sat it back in, pulled it out, etc. too many times. That damn cross member is going to be removable next time! My frame is not great, but it's not horrible. I'd like to take it to a frame shop, have them weld some areas and maybe clean up the frame. Not really sure what a frame shop's capability is with the body on, but I'm willing to pay some money to get my frame better than it is now. Perhaps they can clean it up and put some kind of protecting coating on it? I've seen awesome looking frames on here, but they're all pretty much frame-off jobs and that just isn't going to happen for me.
Old 11-27-2010, 10:53 AM   #15
carriljc
CF Senior Member
carriljc's Avatar
Default Take a look...
If I had to do it again, I would use that kit in one of the messages above. All you have to add is the parking brake wheel bracket, and it would make the exhaust work a lot simpler.
But, you can see how I did mine below....
Quote:
Originally Posted by carriljc View Post
Click the image to open in full size.
If I were to do it again, I make the cuts further inboard.
As far cutting, just use a sawzall or a circular saw. I used a rope saw to cut mine, but there's no need to be that accurate.
All stitch welds completed and painted this gray that I really like.
carriljc is offline   Reply With Quote
Old 11-27-2010, 01:28 PM   #16
jboweriii
CF Senior Member
Default I cut out and put a G-force crossmember in
jboweriii is offline   Reply With Quote
Old 11-27-2010, 04:03 PM   #17
69vettester
CF Senior Member
69vettester's Avatar
I swapped in a Richmond 6sp for my old M20. My crossmember was solid so had to modify it to be a 2 piece.Took some pics and details at this location.
http://69vettester.com/richmond.htm
6speed in a c3 is the cats meow , youll love it.
__________________
69 Roadster, 450HP GMPP 383 bottom end, Pro Magnum Roller Rockers, Brodix IK200's, BG Speed Demon 750, L88 Hood, K&N Extreme flow, Richmond ROD Trans, Centerforce 2 clutch assy & flywheel, Hooker side mounts, STS Turbo Baffles,MSD Pro billet dist. , 6a ignition module, 340 rear composite,460 front coils. Dewitt, Aluminum Radiator, 16" Spal Fan
69vettester is offline   Reply With Quote
Reload this Page 5/6 Speed Transmission Swap
Tags
56, 68, borg, c2, c3, c5, conversion, corvette, corvettet56, speed, swap, t5, transmission, tremec, warner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
