Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2010, 11:03 AM   #1
bucksy99
CF Member
Default How should an engine be started that has not run for 7 years?
I am working on a 75' that has not been started the last 7 years. After doing some research online I found that some people suggest
- drop the gas tank and remove the sending unit power wash the inside of the tank well, if at all possible with HOT WATER.
- unhook the fuel lines at the carb and fuel pump, charcol canister and use compressed air to clean the fuel lines out.
- check cylinder compression (MIN 100 to 110PSI) for all 8 cylinders for a good running engine that has some milage on it.
- change the oil,
- replace the spark plugs
- then turn engine over by hand 2 times before starting
in addition others suggest that the carb might need rebuilding and that when changing oil it should be done with Marvel Mystery Oil because it is really good for the gas and the (existing) oil in the engine
Is this pretty much correct, or is there something that is missing ?
Thanks for any input.
bucksy99 is offline   Reply With Quote
Old 11-20-2010, 11:29 AM   #2
Gale Banks 80'
CF Senior Member
- change the oil,
I think there might be a little bit to much advice here. Wile 7 years is a long time it hasn't been for ever. I'd start by pumping Gas out and losening the Drain Plug on the Engine and check for water. The Engine will probably have some Mosture in it so after its heated up and the mosture is in the Oil its time to change it not before. Charge or replace the battey and see what happens! I'd probably look the Brakes over real good before driveing it then go out and warm everything up and then start changing Fluids.
Gale Banks 80' is offline   Reply With Quote
Old 11-20-2010, 11:49 AM   #3
C3 4ME
CF Senior Member
C3 4ME's Avatar
Make sure you have oil pressure before trying to start it. Preferrably by removing the distrubutor and turning the oil pump with a priming tool, but at a very minimum, pull the power wire to the distributor so it can't fire, and turn the engine over till the oil pressure comes up. This is after you do the above steps and are ready to try to start it.
C3 4ME is offline   Reply With Quote
Old 11-20-2010, 12:41 PM   #4
johnt365
CF Senior Member
johnt365's Avatar
I like those suggestions and would add removing the spark plugs and shooting some fogging oil in each cyl to protect them.
The fuel will be bad and may be clogged in the carb
johnt365 is offline   Reply With Quote
Old 11-20-2010, 01:51 PM   #5
bucksy99
CF Member
Thanks all. I appreciate it.
Do I have to be worried about the piston rings being brittle or a seized up engine before I start it?
Old 11-20-2010, 03:20 PM   #6
BPHORSEGUY
CF Senior Member
BPHORSEGUY's Avatar
NO I don't think so.
BPHORSEGUY is offline   Reply With Quote
Old 11-20-2010, 04:05 PM   #7
RBear571
Junior Member
Support Corvetteforum!
RBear571's Avatar
I just fired up my '70 today that I bought earlier this week. It had not been started in almost ten years. I did all your steps with the tank, lines, water hoses etc. I poured some MM down each sprak plug hole and the intake, waited two days and turned the crank over by hand this morning. I dropped in a battery and after making sure the engine was oiling (as stated above) she fired right up.
RBear571 is offline   Reply With Quote
Old 11-21-2010, 09:55 PM   #8
bucksy99
CF Member
Thanks so much everybody. I will get started this week after I had some turkey....
Old 11-21-2010, 10:08 PM   #9
beachcomber
CF Senior Member
beachcomber's Avatar
Good luck! Please report back once you get to it, would love to hear the update on how it went for you.
beachcomber is offline   Reply With Quote
Old 11-25-2010, 07:10 AM   #10
bucksy99
CF Member
well, the tank appears to be bone dry.
wonder if I need to take it out and clean it ?
Same with the fuel lines. Would be great if I could skip that step.
Old 11-26-2010, 08:41 AM   #11
LT4 F45
CF Senior Member
LT4 F45's Avatar
I would go with a full oil change as soon as possible or before starting it up too. I mean diff oil, brake fluid, transmission fluid, etc... Good luck!
LT4 F45 is offline   Reply With Quote
Old 11-26-2010, 08:47 AM   #12
bucksy99
CF Member
Thanks I was planning on it since it has been a while...
What do you think about the tank and fuel lines ? Do I need to clean them out? The tank seems like it is very dry.
Old 11-26-2010, 10:12 AM   #13
TNX ZORA
CF Senior Member
TNX ZORA's Avatar
If the fuel hose shows the least bit of cracking I'd replace it for sure. Wouldn't be a bad idea to do it anyway if you're willing.
Although some claim you should always keep your tank near full to displace water I personally don't believe that's best. If your tank is empty that's a good opportunity to vacuum out any pieces of trash you see down there around the pick-up screen. I can't drive my '73 right now so I took the gas out and vacuumed the trash out and put the cap on tight. I might get gung ho and put a small bag of deccisent down in there with a hook on it.
TNX ZORA is offline   Reply With Quote
Old 11-26-2010, 05:49 PM   #14
Imo Apita
CF Senior Member
Imo Apita's Avatar
For what it's worth, here is what I would do.
  • Pour Marvel Mystery Oil down the spark plug holes.
  • Let it soak overnight or a couple of days even.
  • Turn the motor over by hand a couple of times
  • Drain the oil and fill with some fresh good stuff(maybe even some break in additive)
  • Disconnect the fuel line at the carb
  • With the spark plugs still out turn over on the starter
  • Watch for oil pressure
  • Put the plugs back in and hook up the carb to a fuel container with fresh fuel.
  • Check the position of the distributor and fire it up.
If it doesn't start replace the carb with a loaner, borrowed or stolen one.
If it does run fine replace all the fuel hoses and flush the tank.
Imo Apita is offline   Reply With Quote
Old 11-26-2010, 06:31 PM   #15
Edzred72
CF Senior Member
Edzred72's Avatar
I would pre-oil (with fresh oil) the engine before turning it over. Just like you would before fireing a new engine.
Eddie
Edzred72 is offline   Reply With Quote
Old 11-27-2010, 06:00 AM   #16
bucksy99
CF Member
thanks
I also got the advice to use 'Sea Foam' to treat the fuel system.
Will give it a try.
Old 11-27-2010, 09:56 AM   #17
Imo Apita
CF Senior Member
Imo Apita's Avatar
Sea Foam is good stuff but is not a miracle worker, it's good to treat the fuel system of a running car.
But it can't get rid of seven years worth of crud and corrosion in a tank.
It also does not miraculously fix rotten fuel lines.
So for now I wouldn't waste my money on Sea Foam.
Old 11-27-2010, 10:35 AM   #18
bucksy99
CF Member
would you take the tank out and clean it and the lines ?
I talked to a guy and he suggested like you to disconnect the lines at the carb and crank the engine. The old fuel that is in the lines should come out. I believe there is not much left in the tank. Then change out the fuel filter and connect back to the carb.
Old 11-27-2010, 07:32 PM   #19
Imo Apita
CF Senior Member
Imo Apita's Avatar
Bucksy, I am not recommending anything, I'm just stating what I would do in a similar situation.
Fuel line is cheap, you buy it by the foot at any discount auto store, I'd replace it all.
I would drop the tank and flush it or have it professionally cleaned, corrosion in the tank will have you chasing issues for months to come.
Anyways you mentioned in your first post about starting it, nothing about driving it (yet).
So me thinks the prio is to get the engine running with a separate fuel source and leave the tank for later.
Old 12-04-2010, 10:27 PM   #20
bucksy99
CF Member
I did the above steps the engine is running but from a different fuel source. I couldn't get any fuel out of the line after I disconnected it from the carb. There is a little bit fresh gas and sea foam in it so something should come out...
I really want to avoid having to drop th tank. Can I disconnect the line at the tank and try to blow it out with air before I get into anything else ?
Reload this Page How should an engine be started that has not run for 7 years?
Tags
25, car, carbed, engine, gas, hasnt, ran, run, running, start, started, tak, treat, vehicle, years
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
