Street Avenger Stumble Issue Solutions
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
I keep running into Holley Street Avenger carb problems related to off-idle stumbles and part throttle hesitations. I've seen these issues on the Tuning for Beer Tours, and I just had yet another SA carb (the 4th one with these issues) sent to me with these problems, so I thought I'd share the issues and solutions with you.
There are 2 problems on the Street Avengers that cause the stumbles and hesitations:
Forget about swapping pump cams and accel pump nozzles - that's not the issue, and it won't solve your problems. Fix the pump lever geometry instead...
- Lean Jetting. The S/A carbs are jetted very lean on the primary side, and extremely lean on the secondary side. Bump primary jetting up about 3 jet sizes and then make the secondary jets 8 sizes larger than the resulting primaries. To save a few bucks on jets, take the jets out of the secondary side and install them in the primary, and then just buy a pair of jets for the secondary side. This gets the carb jetted about right and will do wonders for throttle response and power.
- Accel pump lever not touching pump cam. I see this constantly on the S/A carbs, and it's really lousy assembly work at the factory: The accel pump lever that connects between the pump cam and the accel pump arm does not ride on the pump cam at idle. The lever is riding on top of the throttle shaft spring and is not touching the pump cam. Only after you rotate the throttle a bit (with no accel pump action) will the pump cam touch the lever and produce a pump shot. To fix this, remove the lever and bend the lever a little more right where you see the "kick-up" bend in the lever where it's supposed to ride on the cam. By giving the lever more of a bend, the lever will not hit the shaft spring and will ride on the pump cam right where it should. This will produce an instant pump shot off idle, and will solve most of the hesitation/stumble issues associated with these carbs.
The ORIGINAL and bestest
Toronto Events Coordinator
Been there, and done that! I still remember wondering why the hell we couldn't get rid of the stumble on my SA until we realized what was happening with the accel pump lever!
Good information here. I fattened my primaries up 2 and it helped some. Getting the timing just right has helped the most for me. I guess I need to see if I can adjust on the pump lever a touch too.
Bless you sir! I swapped from an edelbrock to avenger and have been monkeying with pump cams because I noticed what you mentioned about the pump cam not activating as you break idle, and resulted in a stumble. I've gotten used to stabbing the gas a little to get past the stumble point. You're the man. My jetting seems to be close however but may richen it up and see if performance improves.
Thanks Lars
Do I have to disasemble the carb to change jet's? And what about changing the powervalve, do I have to disasemble carb to change it? I only have 8 inch of vacum so I should maybe change PV to a 5,5 unit if that excist.
To make sure I understand, I just looked it up and the 770's come jetted from the factory with a 72 jet on the primaries and a 75 on the secondaries, so your saying put the 75 jets on the primaries and put 83 jets on the secondaries so to have 8 jetting sizes larger on the primaries compared to the secondaries? Thanks.
Edit: Sorry I meant to say have 8 jetting sizes larger than on the primaries.
Yes, they make 5.5 PVs, and that may be a good choice given your 8" of vacuum.
Thanks for the tip Lars. I have a 770 that I am planning on using for my build.
I am new at the jet changing. Is the jet size clearly marked on the jet so that you can tell if someone has changed them out in the past?
Okay... If I need to get larger jets... where do I get them? I tried looking on the Holly site but couldn't find them. (I may just not be looking at the right place so direct me if you can)
Also can't find a dealer in Canada. Is there a refeence # I can use for a different brand maybe? (out of a skidoo??? )
shmoky
shmoky
shmoky
shmoky
shmoky
shmoky
Lars
1st try the pump cam lever.
larger jets waste gas. if it is too lean it will surge at cruise. ask yourself, does it surge?
